Go to Post Just keep doing. Everything. Keep designing, keep building, keep learning, keep fundraising. Build more robots, try more ideas, compete more and more and more. - [more]
Unread 30-05-2002, 00:21
Rick Gibbs Rick Gibbs is offline
#0145 (T-Rx)
Rick Gibbs is an unknown quantity at this point
Question Drill Gearbox Gear Size?
From what I've read, the drill pinion is a 0.7 module (which means it's metric?). Does anyone have any information on the gears (suns, planets, rings) inside the gearbox? Is it a safe assumption that they are 0.7 module also?
Unread 30-05-2002, 21:26
Matt Reiland's Avatar
'The' drive behind the drive
It looks like the first 2 stages are 0.7 mod, I get the mating gears for it from PIC-Design.com. We only used the motor pinion on our gearbox last year.
drill motor gear noise arshacker Motors 2 04-02-2003 19:52
drill gearbox schematic? Jeff Sharpe Technical Discussion 3 21-01-2003 00:18
Info on gear on drill motor archiver 2000 2 23-06-2002 22:58
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
