Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 27-07-2005, 23:19
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Re: Limit_Mix() Function
Thank you very much. Yes, I did understand that the actual mixing was don in the calling line, I just worded it wrong. Basically you said what I already knew, but somehow I feel I understand it more now, so... Thanks.
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
RoboEmu2(code simulator)--now with C! rbayer Programming 23 17-02-2005 09:17
