Go to Post The short answer is there is no shortcut. - JDNovak [more]
Unread 30-07-2005, 01:19
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Illusions
Found this illusion site, so weird.
http://www.echalk.co.uk/amusements/O...erception.html
http://www.mikesorrenti.com/
Unread 30-07-2005, 01:25
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Illusions
Ebaums also has a bunch of good illusions. illusion 1 and 3 are wrong. if you look close on 1 square A is spiked with darker piments and B has occasional lighter ones. on 3 even with the blind i can see a color difference.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 30-07-2005, 06:15
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Illusions
Well, apparently your eyes are better than mine, Brain. The illusions work on me.
I have seen the first two before, but not that last one.
Unread 30-07-2005, 08:22
Re: Illusions
do you have your monitor set for 24 bit or true color mode?
you can screen grab those web pages by hitting the [print screen] button on your keyboard, then [ctrl][v] paste them into paint
and capture the color from one area and draw it into the other - or cut and paste parts out of the pictures and put them side by side
the colors are identical.
Unread 30-07-2005, 12:42
Re: Illusions
yes the colors are but their is a spray of pixels that aren't!
Unread 30-07-2005, 14:58
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
Re: Illusions
the first one does have some variances in exact color because the image appears compressed and it caused some slight changes in color, however there is the same amount of the same color pixels in each square, all arranged in about the same pattern. I tested this in photoshop and was impressed how similar they were. I also made this quick gif that overlays square A and B to show how similar they are in color
on 3rd image, I am sure that the objects are the same color, but because it is a 3d rendering, the shadows make it nearly impossible to check in photoshop. I took 6 samples of the cross in the middle for each cross, but I never managed to get the exact same color, but the colors were very similar, enough to prove the point the author was trying to make in the website.
just my $.02
http://www.wcsrobotics.com
team 663
team 1493
Unread 30-07-2005, 18:48
Re: Illusions
yeah I'm just a perfectionist thats why i can pick out individual pixels!
