Go to Post How the mentors of a team inspire their team is unimportant, as long as the team is inspired to do great things. We on 1824 believe in 'student designed, student built', but that does not mean that all teams should do as we do. For inspiration comes in many forms. - Daniel_LaFleur [more]
Unread 31-07-2005, 17:15
supertw supertw is offline
supertw will become famous soon enough
Help with limit mix
what's the point off adding 2000 to the following functions:
pwm01 = pwm03 = Limit_Mix(2000 + PWM_in1 + PWM_in2 - 127); /* LEFT WHEELS */
pwm02 = pwm04 = Limit_Mix(2000 + PWM_in2 - PWM_in1 + 127); /* RIGHT WHEELS */
the coding seems all fuzzy to me, i dont' get it
Unread 31-07-2005, 17:20
Morenoh149
Posts: n/a
Re: Help with limit mix
I'm n00b myself so maybe I'm wrong.
I had problems with this myself when I came across it.
I think it has something to do with the hardware
it is slower to run the program if it starts getting decimals (floating point #'s)
I think later in the program it negates the 2000
correct me if I'm wrong
Unread 31-07-2005, 18:40
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
You're right, noob. () It does that just so that it can get decent precision without decimals or negatives.
I think...
Unread 01-08-2005, 13:07
The compiler we use has the irritating feature of choosing eight-bit arithmetic when adding eight-bit quantities. That often results in overflow and unexpected results. Adding a constant 2000 to the expression forces the compiler to do things using 16-bit arithmetic, and everything then works as it should.
The Limit_Mix() function subtracts 2000 from its result, neatly compensating for the extra 2000 in its input.
Unread 01-08-2005, 13:28
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
The Limit_Mix function assumes that its input value has had 2000 added in, and thus subtracts it back out before returning.
Back in the Basic Stamp days, there were certain circumstances where it was necessary to avoid negative numbers. This Limit_Mix function is a legacy of those days. By rights, the function should now be:
unsigned char Limit_Mix (int intermediate_value)
  static int limited_value;
  if (intermediate_value < 0)
    limited_value = 0;
  else if (intermediate_value > 254)
    limited_value = 254;
  else
    limited_value = intermediate_value;
  return (unsigned char) (limited_value);
And the calls would be:
pwm01 = pwm03 = Limit_Mix(PWM_in1 + PWM_in2 - 127); /* LEFT WHEELS */
pwm02 = pwm04 = Limit_Mix(PWM_in2 - PWM_in1 + 127); /* RIGHT WHEELS */
Unread 01-08-2005, 13:38
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
OK. I forgot about the 8 bit quirk. Adding the 2000 bias does circumvent this trap, but it's an awfully kludgy way to do it. I assert the following would be clearer: (Assuming that all the definitions remain eight bits each.)
pwm01 = pwm03 = Limit_Mix((int)PWM_in1 + PWM_in2 - 127); /* LEFT WHEELS */
pwm02 = pwm04 = Limit_Mix((int)PWM_in2 - PWM_in1 + 127); /* RIGHT WHEELS */
Unread 05-08-2005, 13:49
Morenoh149
Posts: n/a
so what does the (int) do?
does it make the PIC treat all variables (PWM_in2 & PWM_in1) in the Parenthesis like an int instead of a char ?
Unread 05-08-2005, 14:03
It makes the compiler treat the variable with the (int) in front of it as an int. However, having even a single int in the expression causes the compiler to choose 16-bit operations to evaluate the result, even if everything else is only 8 bits in size.
Unread 05-08-2005, 14:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
The (int) is something called an explicit typecast. It forces the variable right after it to be converted into an integer type, which in our case is a 16-bit signed type.
This "Limit Mix / why add 2000?" question is one that gets asked A LOT by teams up in Canada. I usually refer people to a post on the FIRST Greater Toronto Regional forums:
http://www.firstcanadianregional.org...opic.php?t=500
Hope that sheds some light into the situation!
-SlimBoJones...
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
material cost limit haverfordfords Fundraising 3 06-12-2004 19:21
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
