Go to Post EXPERIMENT in the off season! - DonRotolo [more]
Unread 27-07-2005, 20:02
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Re: pic: Robo-one legs
yeah I'd like to see a wheeled robot do a back flip, lol. But if you could provide any code examples it would be nice. I'm not much of a programmer.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 27-07-2005, 20:35
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
sanddrag makes a valid point but i think you are going to see more motor problems at the bottom. if you can run different amounts of current to different motors run about 8 volts to the bottom motors.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 27-07-2005, 20:36
[527]phil's Avatar
Alumni
AKA: Phil
I figured out one major problem with the legs, i need to take out one servo from each leg, not only will this make it more stable, it'll make it easier to program.
Unread 27-07-2005, 20:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think 8v is far too high for most hobby servos. I think about 6v is the max.
Unread 27-07-2005, 20:54
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
I was beginning to wonder why you had some many servos. You should only need 3 per leg (just like human legs) including ankles. It would definatly make things easier.
-Mike
Unread 27-07-2005, 21:02
i like the idea too often i see robots bound by the constraints of biology. make biology the base and then improve!
Unread 27-07-2005, 21:58
Gdeaver Gdeaver is offline
FRC #1640
If I remember your past post about the atom, there was a problem with your use of the servo command. Look at the docs on the servo command.
Servo 1,5 will repeat this command 30 times by default which takes about 1 second to execute. Try servo 1,5,1 This will take about 30 ms to execute.
To control that many servos you going to need a servo board. Most servo boards are serial or I2C controlled. Serial is probable easier, I2c is most likely faster.
Unread 27-07-2005, 22:17
you can run the Hitec and Futaba servos on 12 volts DC even though its rated for 6 volt. also you can run almost any servo on roughly 8 volts.
Unread 28-07-2005, 15:47
[527]phil's Avatar
Alumni
AKA: Phil
this is robo-one legs 2.0. I took off the knee servos and not only is it shorter, it's much more stable.
Unread 28-07-2005, 19:54
hehe he's stubby!
Unread 29-07-2005, 22:58
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
-Mike
you should need 4 servos per leg cuz the leg has to rotate 3 ways(forward/back, left/right, and to rotate the whole leg) that way you can turn
Unread 29-07-2005, 23:54
ive been compiling info to write a whitepaper on bipedal walking so tell me how this turns out. one of the things i want to see and i think would be extremely usefull to a better system would be the addition of bending toes and able to lean side to side. both of these are extremely important to human balance. if you don't believe me try walking without bending your toes or shifting weight from side to side.
Unread 31-07-2005, 17:02
[527]phil's Avatar
Alumni
AKA: Phil
It's having a weee bit of trouble walking, but it's not because of my designs it's because of my programming, I still haven't mastered the HSERVO command, + I've been searching for a Pentium 3 laptop, kinda like an IBM think pad or a dell latitude, but alas i keep getting overbid .
what happened to the pic of legs 2.0?
Unread 31-07-2005, 17:49
but can it actually move?
Unread 01-08-2005, 14:14
[527]phil's Avatar
Alumni
AKA: Phil
Yes he can move. all servos work perfectly and I calibrated the servo horns so they are at the 0 position (or almost). I can move single servos or multiple ones. It's just in order for it to walk on it's own i have to find the exact placement of each servo so it won't fall over. But it's alive!!!, lol
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
pic: Team 522 Robo Wizards Mckee H.S. Staten Island N.Y. CD47-Bot Robot Showcase 18 17-04-2003 20:40
