Go to Post "So we have an arm, and the pot on it tells how high we are... ...and then we know how high we want to be... ...and if we're not high enough we go higher." (I have to leave the room, we're all laughing too much.) - demosthenes2k8 [more]
Unread 01-08-2005, 03:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
pic: Demo Transmission 222
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 01-08-2005, 03:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Demo Transmission 222
I'm wondering if a laser machine would be able to burn out some lexan (0r acrylic) gears without melting it. It doesn't have to be super precise, just functional enough for a demo box. If not, maybe a waterjet? Do you have access to either of those? With proper indexing equipment and a gear cutter you could even cut your own gears on a mill.
I'm not totally going for the friction wheel thing. I think gears would be way cooler, even if some extra work is involved.
Unread 01-08-2005, 04:12
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
waterjet would not be good for gears. they don't cut at a perfect 90 degrees.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 01-08-2005, 04:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
gears don't have any 90* angles except for the face of the edge of a tooth.
It's not going to run under load at any rate, so they don't need to be perfectly precise.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-08-2005, 04:40
but if its not a good fit you get serious probles. for example a section of the gear isnt close and it pushes on other gears. it could case a jam, wear, or chipping. with most drivetrains you want close to perfection. look all i know is that you dont use a waterjet to cut gears and this doesnt just come from me.
Unread 01-08-2005, 05:02
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Since its just a demo gearbox, and they're using a polycarbonate, precision isn't that necessary, it just has to work. Even if the tolerances are out of whack, the gears will break-in and all will be well.
And I second sanddrag, gears do look cooler, haha. But that's my opinion, I'd be too lazy to cut plastic gears and just stick to the plastic wheel ideas, maybe put a layer of epoxy or rubber cement on them to increase friction. I mean, it just has to show the shifting mechanism; if anyone is curious about how it does with real gears, just show them your robot =)
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 01-08-2005, 05:06
Cory's Avatar
AKA: Cory McBride
http://www.thefabricator.com/Article...cle.cfm?ID=646
2001-2004: Team 100
Unread 01-08-2005, 07:07
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
whoa, wait a minute...i know for a fact that team 42 has been using a waterjet for the past "...x..." season to cut their massive lexan gears. they seemed to work fine and didnt bind or have meshing problems at all.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 01-08-2005, 07:57
Gdeaver Gdeaver is offline
FRC #1640
I have always considered the 222 trans elegant compared to the brute force dog shifters common on first designs. How ever that pneumatic shifting set up is kind of a Kludge. I don't know what kind of force is needed to move the shifting shaft in and out . In 2005 the number of Hitec servos was not limited. What if you took a plastic cylinder and cut it at an angle. When the 2 halves are twisted you would get the in out motion. One servo probable isn't enough but, 2 might do it. If it works it would cut out allot of weight and eliminate the need for Pneumatics.
_____
_\ /_ If this makes sense
Unread 01-08-2005, 13:39
AKA: Bradley Rigdon
I agree gears would be cooler to have in this gearbox, but the only machine we could attempt making gears with is the CNC Mill and with limited knowledge on how to use it, the gears would be difficult to make.
The other problem with gears is that it would probably be difficult to see inside were the shifting occurs, this too may also be a problem with just "wheels" in their place.
Are you referring to the 2004 three speed or the 2005 two speed shifting setup?
We thought about using servos, but we just had too many problems with them in the past when using them to shift the drill motor transmissions.
Not sure exactly what you mean by cutting the cylinder at an angle?
Last edited by team222badbrad : 01-08-2005 at 13:44. Reason: Wow, I did not know Henry was posting and he did not know I was posting, the funny part is we both posted at 1:39...
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
As far as all the extra waterjet discussion is going... we don't have access to one, a laser mill either. We were also looking into gear cutters to make our own gears once the 06 build rlls around, but we do not have one now.
The tolerances can't be too wrong, polycarb has a hardness that is measured on the Rockwell scale, so it isn't exactly going to wear in very easily, but it is after all just a demo transmission. I did like the idea of epoxy or rubber cement. We could probably use the normal tolerances with the 05 transmission plates and use the depth of the rubber cement applied to account for the missing teeth on polycard wheels.
The servo shifting idea was discussed. The shifting is definitly possible with servos, and I bet it could be done reliably with one servo per transmission, but 2 servos per side would be the only safe way to go about it IMHO. That leads to the battery drain. The servos are run entirely off of the backup battery (correct me if I am wrong) so we didn't want to take the risk of running a low backup and not being able to shift. In the end our discissions boiled down to simplicity. Powerful air BAM one way BAM the other; physical stops each way. Done.
I believe 469 used a leadscrew setup with a globe motor powering the single screw which shifted both of the joined transmissions. I also believe that 571 and 1143 used pneumatics like us. The only other team with this transmission setup is 476 (??) and I am not sure what they use.
-Henry
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 01-08-2005, 14:07
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I have always looked up to team 222 for the way they build their transmission. Specially the shifter.
Just like Henry pointed out before me, that you can shift with globe motors. Team 233, The Pink Team used globe motor to shift or I was told. Take a look at their machine if you get a chance. Or get in touch with someone from their team.
Unread 01-08-2005, 19:44
I got it. Don't bother with rubber cement or anything. Just put wide rubberbands on your polycarb/acryllic gear-wheels. Make sure you get your center to center distance right though for good contact between the rubber bands. Enough contact to hold, but not excessive friction/binding.
Unread 01-08-2005, 22:15
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
A few notes about laser cutting:
One of our few sponsors owns a shop specialized in laser cutting, so most of our "professional" looking parts are made by him.
He has cut us several acrylic gears and we didn't have a problem with that (except... acrylic shatters - rookie mistakes ), though it should be noticed that those were large pitch gears - for the window motor, I think. Not sure if finer pitch gears, like 20 or 32 DP, would be cut correctly.
Another thing to notice is, allegedly, bad gases are released when polycarbonate is heated/melted, so he only cuts it when the shop is closed. Since we are thankful enough for his sponsorship, we don't ask him to cut any polycarbonate for us. That'd probably be a similar issue with other laser cutting shops: they won't do it or maybe they'll charge you a ridiculous amount for it.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 02-08-2005, 07:08
FRC #1640
Some small timing belt super glued to the circumference of the polycarb would allow a fairly functional gear. No machining required.
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
pic: Tigertrons 222 05 Pic #2 team222badbrad Robot Showcase 4 01-03-2005 08:25
pic: Team 30 Dual-Motor Transmission CD47-Bot Robot Showcase 27 10-02-2004 18:35
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
pic: Demo Girls! CD47-Bot Extra Discussion 2 14-04-2003 11:21
