Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 02-08-2005, 01:01
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
where do tyou buy the battery connector and circuit breaker
i was wondering where you buy the connectors for the batteries and the circuit breakers because they are going to be for my personal robot that i have built and now improving along, and they are the only one i have seen that work so well
Unread 02-08-2005, 01:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: where do tyou buy the battery connector and circuit breaker
http://www.powerwerx.com/category.asp?CtgID=3579
http://www.powerwerx.com/category.asp?CtgID=3578
http://robotcombat.com/marketplace_connectors.html
http://delcity.net/delcity/servlet/c...=193073&page=1
hope that helps.
No guarantee these are the exact parts in the kit, but they should work for your application. The kit battery connectors are the red 50Amp SB series and are not sold with pre-crimped leads. You will have to crimp or solder them yourself. I'm not confident that the circuit breaker is identical, but it looks incredibly similar.
Unread 02-08-2005, 02:07
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
wow, that is fricking awesome, i am so0o happy now!
do you know anywhere to buy batteries that have the same aperage rating but smaller in size then the ones we use?
Unread 02-08-2005, 02:16
Nope, SLA batteries will always be pretty much that size for that Ah rating. I know where to get you similar ones for cheaper though (probably about $25 for the 17 or 18 Ah) http://www.bb-battery.com/productsbp.asp
Those are the general ones, you can see all their other more expensive ones here http://www.bb-battery.com/products.ASP
Unread 02-08-2005, 02:23
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
what about a battery with a different chemical compound?
Unread 02-08-2005, 02:28
I don't think you're going to get that kind of capacity outof NiMH or NiCd unless you go in parallel with a bridge rectifier setup. I don't know that much about putting NiCds or NiMHs in parallel. About the NiMH batteries themselves, the most common form is Sub-C size cells with 1.2V each and up to 3800mAh of capacity each. You can buy them preassembled in series in packs for higher voltage. But then you'd want multiple packs in parallel for more capacity. However, I remember hearing that if a bridge rectifier is not used, the current will flow back and forth between the two until they discharge themselves.
Unread 02-08-2005, 04:46
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
I don't know much about bridge rectifiers, but I know that putting NiMH or NiCD cells in series can be done. I saw some large packs of batteries somewhere online, I don't remember where, but I remember that they have been used for Battlebot type robots. I also stopped by my LHS to pick up some stuff, and they had large NiMH battery packs that were about 30 or so NiMH cells in 3 series of 10 batteries. It was about 12V at 10Ah, a little smaller than the average batteries we use in FIRST, but it was also very expensive. I'm sure they make chargers for a 12V NiMH pack, but charging it would take a long time because of it's Ah..that is if you want to keep the batteries in the best condition possible for a longer life...And discharging would take quite a while.
Using a SLA battery would be a better choice, less maintenance and plus, you don't really have to discharge them to store them like you would a NiMH pack.
Unread 02-08-2005, 07:02
Gdeaver Gdeaver is offline
FRC #1640
B. g. micro is selling anderson conectors.
http://www.bgmicro.com/pdf/lma.pdf
Unread 02-08-2005, 07:42
Starting off with the bridge rectifier discussion...
Batteries do not need to use diodes when in series. The current SLA battery is six 2 volt cells in series with no diodes. Use diodes (a single diode in series with each battery, not a bridge) when paralleling batteries so that the batteries don't self discharge each other. Diodes are available from RV stores or use Schotky diodes that have a very low forward voltage drop.
Other battery types can give significant currents in the same package size as our current SLA but there are drawbacks like cost, type of charger, and damage potential. And yes, NiCad cells are available that are larger than normal battery sizes.
Unread 02-08-2005, 15:36
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Just note that Anderson SB series connectors of different colors are keyed differently (you can't use a red and a yellow), so if you wanted to use any FIRST batteries you would have to buy red ones. You can mix the PowerPoles, however.
For the money and the ability to take abuse, you are not going to find anything much better than an SLA. By "amperage rating" do you mean capacity (Amp-Hours) or max discharge current (Amps)?
Unread 02-08-2005, 17:57
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
i mean amp hours, and why would i have to buy red ones? cant i just buy 2 of whatever color i want?
and the colors are interchangeable as long as they are the same series with the same amperage rating
Unread 02-08-2005, 19:13
FRC #0190
I meant that if you wanted to use batteries that already had the red ones. And yes, all the contacts for the SB50's are the same. In fact, I'm almost positive the SB50 contacts are the same as the PP75's as well.
Unread 05-08-2005, 16:30
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
o yea i could figure what you were talking about, i am buying them for a personal project and i didnt know any connectors came with the kit, they were always just magically on our batteries when we need the batteries
Unread 05-08-2005, 18:40
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
My favorite source for Anderson Power Products:
ROSSPAR
They sponsor FIRST teams in and around the Greater Toronto Area as well, and are based a block away from where I work. The people there are amazing, and I've been known to drop by there on my way home during build season for both connectors and advice.
They carry the vaunted crimping tool for the SB50 series contacts... but recommend soldering them if you don't have a proper crimper. (Fill, melt, dip, release! Works great too!) They would've lent me a crimper, but at the time they'd lent out all their extras.
Also, they were nice enough to inform me why in the past our connectors sometimes wouldn't stay together nicely: There are different contacts for the SB50 connectors with different insertion forces (high detent and low detent). If you mix different types, the result is less than optimal.
-SlimBoJones...
P.S. They have extremely competitive pricing! It's worth calling them to price out what you need, and don't forget to mention you're involved with FIRST robotics!
Unread 05-08-2005, 20:25
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
wow thanks!
Backup Battery...Yay or Neh? dez250 General Forum 31 05-05-2004 17:08
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
