Go to Post the robot is never done that it just evolves less rapidly - sporno [more]
Unread 02-08-2005, 02:19
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
is it a solid or a fluid?
i remember a while ago watching this thing on tv that was showing new shocks in a car, i dont remember what kinda car, but the stuff in the shocks was a substance that either reacted to electrical current or magnetic fields, i am unsure about which one it was, but when it reacted it would harden up
i was reading a post buy FIRST_jersey kid in the educational robotics about a brake system then they were going to try next year, and if you wanted to make brakes with that stuff would it be legal in terms of FIRST's rules and regs?
for the system you could maybe do multiple pieces in a cylinder that were cut out of some thickness of metal that would be low drag and have that cylinder full of that substance so that when you apply either current or a magnet field(i dont remember what one) it would harden up and not beable to rotate
Unread 02-08-2005, 02:22
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: is it a solid or a fluid?
or you could even maybe do use it for a transmission so that you have certain parts in a cylinder but then when you harden it up the whole cylinder would ratate inside a bearing it is in
like a planetry transmission with no clamps or movement, it would in theory be a good shift-on-the-fly transmission
Unread 02-08-2005, 02:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I saw the exact same show you are thinking of. The stuff is called ferrofluid (google it). It is basically fluid with lots of very very fine iron filings/dust in it (at least that's my understanding of it). Not sure if it would be allowed in FRC. Cool stuff though.
Unread 02-08-2005, 08:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The technical term is actually a magnetorheological fluid (MRF). Ferrofluids just attracted to magnetic fields, they don't change viscosity or anything. I'm unsure about using it as a brake, however. While it solidifies under a magnetic field, that's only while the pressure applied to it doesn't break the chains of nanoparticles that are solidifying it. Think of it as really quick setting jello as opposed to ice. So as a brake, it'd be somewhat less that useful. Viscous braking isn't typically useful anyways, as viscous resistance is dependent on velocity, so you wouldn't have much luck sitting in place not moving.
Unread 02-08-2005, 10:15
There has been some experimentation using these multistate fluids in CVT transmissions. By varying the excitation you get variable coupling with very little loss. This is an outgrowth of the study of snail locomotion. Snails produce a mucous that is fluid but turns solid enough to push against under pressure. Works OK for the snail but they spend a lot of time producing the mucous.
Unread 02-08-2005, 10:24
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Wow!!! No there's a thought. "Mucus drive".
I think any competition using this would get very boring very fast. Not only slow, but messy!
Unread 02-08-2005, 10:39
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
I've been intending to play with MR fluids for several years. As soon as I find the time.
A good source of information is the Lord Corporation MR Fluid Home . There are several technical papers there and a list of outside references.
There is a recipe for a DIY MR Fluid using readily available materials. The commercial products are a bit pricey for playing around.
Greg
Unread 02-08-2005, 16:59
Kevin Watson's Avatar
La Cañada High School
FRC #2429
The C5 corvette had an option for variable damping shock absorbers that used a magnetorheological fluid. I'm not sure if this option is still available on the C6.
-Kevin
Kevin Watson
http://kevin.org
Unread 02-08-2005, 17:14
FRC #2429
It's not a magnetorheological fluid, but a mixture of cornstarch and water in the proper ratio has the neat property that it will flow like a fluid if poured from a container, but act like a solid if impacted or moved quickly. This is an example of a class of materials called non-Newtonian fluids. Here's a google link where more information can be found.
-Kevin
Kevin Watson
http://kevin.org
Unread 03-08-2005, 13:00
Science Enabler
-Kevin
Is the link not working? It should take you to a page titled "Dr. Dave's Do-It-Yourself Magnetorheological Fluid". It uses iron filings, low viscosity oil, and lithium grease.
I haven't tried the recipe (that time thing), but the page says it will work for demo purposes.
Greg
Unread 05-08-2005, 00:50
Elgin Clock's Avatar
FRC #0237 (Black Magic)
That stuff is so cool, and so easy to make.. it's just a matter of getting the proportions correct. The cool thing to do is to make some in a small bowl and let your finger/hand just slowly sink in it. Then when you go to pull it out quick, you can't.. You have to work it out slowly again.
Fun stuff to mess with in a kitchen laboratory.
Unread 05-08-2005, 01:05
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Interesting it sounds like this liquid reacts kind of like piezoelectric polymers (despite a completely different composition). I wonder whether its being put to applications besides shocks?
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Converting datum curves to Solid daramana Inventor 0 16-02-2005 23:14
fluid & vo vs. dean & woody Jack FIRST Scouting Network 5 28-06-2003 21:00
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
solid edge solid works ceileachair Inventor 1 21-01-2003 22:03
solid edge ver 12 ceileachair Inventor 1 19-01-2003 21:15
