Go to Post As far as we know, FIRST could replace football by 2018! - Adam Richards [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 14-05-2005, 10:46
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Re: Self-Balancing 2 Wheeled Robot
You might want to try looking at the Robo fire fighting competitions because most of their robots look like that. Just find somones e-mail and ask them questions, thats how i got started with robo one.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 30-05-2005, 12:33
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Mike, I have built a balancing robot (years ago) http://www.barello.net/gyrobot
You can't do it with a static linear accelerometer. The acceleration of the body, left, right, will change the observed gravity vector and the algorithms will fail. You need a gyroscope. Gyroscopes are insensitive to linear accelerations, and only sensitive to rotational acceleration. The old FIRST gyro is what I used on my balancing robot. Gyro's drift, so you need to correct them in some way. My original balancer used the wheel drift to compensate by feeding the position error back into the balance equation. It actually worked really well, but the math overflowed after a while.
A lot of other folks use a kalman filter to fuse a tilt sensor (linear accelerometers) and a gyro. The former is used to correct the gyro and the latter is used to handle rapid rotational changes. Microstrain FAS-G is an example of such a beast. I am math challenged, so I implemented my own lame version: I simply took a very small fraction of the difference between the tilt sensor and the integrated Gyro tilt and added that back into the integrated output. It was .01, IIRC. The effect was to essentially ignore short term noise from the accelerometer due to body movement and to cause any long term drift of the gyro to be "pushed" back towards whatever the tilt sensor indicated. I got my tilt sensors as samples from www.analog.com and the gyro from old FIRST kits, so I had a zero cost.
A third option is to use some sort of direct measurement, like a potentiometer with a tail that touches the ground, or optical distance measuring doodads like the sharp GP2D12. That approach makes it easy to balance since you have an absolute measurement of tilt without any drift, but, of course, they have their problems...
A pendulum on the potentiometer will have the same problems as a linear accelerometer: if the body accelerates left or right, the weight will shift and "down" will change and, again, the algorithms will fail.
The old FIRST gyros work really well and are easy to use. They are "too" sensitive for any serious movements as their output limits at 65 deg/sec. For our FIRST robots in 2004 & 5 we used the Analog devices ADXLR150 gyro chips. Get the "EB" (evaluation board) versions for $50 and worth every penny. The 150 will go to +/- 150 deg/sec which is more appropriate.
Good luck!
P.S. You found a vision tetra and capped? Way to go. We spent three weeks beating our heads on that one and gave up. We could find the tetra, pick it up 100% and always hit the center goal, but we couldnt actually get the dang thing on top! The speed needed to do it in 15 seconds made our position errors too large by the time we go to the goal and it never quite made it. We chose to do something simple and 100% reliable: Grab a goal from the auto loader and put it on the corner.
Unread 30-05-2005, 19:32
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Thanks for the advice , I got my birthday money today and plan on buying your AVR controller soon (for this project and future ones). Odds are, for the current time, I'm going to be using a potentiometer attached to a stick with a ping pong ball at the end. Eventually I'll probably use an IR distance sensor.
http://www.mikesorrenti.com/
Unread 12-06-2005, 17:15
[527]phil's Avatar
Alumni
AKA: Phil
http://robots.net/robomenu/995142345.html
Unread 12-06-2005, 23:24
Mike's Avatar
AKA: Mike Sorrenti
Thanks for the link... as far as my robot is going I probably won't be able to get it done for a while. Still lacking in the funds department.
Unread 27-06-2005, 11:05
GhostInTheShell's Avatar
GhostInTheShell GhostInTheShell is offline
AKA: Derek Vance
GhostInTheShell will become famous soon enough
i made this kick butt gyro thing w/ a joystick and a gyroscope and a motor,
i would put up pics, but never the less, my cad software is not working right
"i reject your reality and substitute my own",
Adam Savage, Mythbusters
"it's kinda private in here"
Jamie Heinamin, Mythbusters
Unread 29-06-2005, 14:22
[527]phil's Avatar
Alumni
AKA: Phil
So let me get this strait, you made a gyro, with a gyro. lol just kidding, I used a gyro in two of my robo one robots, and i'll probably put one in on my third. I use the gyro made by parallax, seems to work well.
Unread 29-06-2005, 18:20
Mike's Avatar
AKA: Mike Sorrenti
How did you guys do programming the Kalman filter?
Unread 29-06-2005, 18:40
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
you know there are some guys at the university of Maryland working on something similar it involved a pendulum swinging and being able to counter balance it with electronics so a camera mounted on the end would have a perfectly level image..... of course i could just be blowing smoke out of my mmmmhhmmm *throat clearing*
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 29-06-2005, 21:23
Mike's Avatar
AKA: Mike Sorrenti
Heh, no your right. In most of the new cameras out, they use gyro's to stabilize the image.
Unread 02-08-2005, 15:12
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
balbots.com
FYI Look Here for a cool place to start to play with a balancing robot.
Flat floor limitations (if you are clever, you can probably can find work around for this limitation) as well as other limits, but it is as good of a place as any to start.
Joe J.
P.S. I'm not here and you didn't read this ;-) I am much too busy at Robotic Amusements, Inc., getting ready for our product launch at the AMOA Show in Sept. Wish us luck...
Team #88, TJ2
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 19-01-2005 11:35
THIS TIME TEAM 438 BALANCING ROBOT archiver 2001 1 24-06-2002 01:01
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
