Go to Post Yeah.... I'll pay money just for a picture of Andy [Grady] getting jiggy! (then recommend it for the Caption contest!) ;) - Rich Wong [more]
Unread 02-08-2005, 23:30
PhusionReactor PhusionReactor is offline
None #1502
PhusionReactor is an unknown quantity at this point
Radio Transmiters
Does anyone know were I could maybe find a Radio Transmitter for our teams Edu Bot? I'm my teams new programmer, and I could use some practice programming an Edu Bot with a controller. So far I have a basic little program set up with it. It just goes around in a square. Anyway, If anyone could maybe give me a good website URL that has some transmitters that are relatively cheap that I could order for my team, that would be cool.
~Thanks!
Team 1502 Apprentice Programmer
Unread 02-08-2005, 23:33
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Radio Transmiters
You can get it from IFI. Good luck.
Unread 02-08-2005, 23:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
This Futaba Ground radio is a little bit cheaper and as a bonus you get a couple or servos. http://www2.towerhobbies.com/cgi-bin...I=LXBCP2**&P=0
None #1502
I cant seem to find any hobby raidio transmitters on here for an EduBot. Could you maybe supply an exact URL? Thanks.
Unread 02-08-2005, 23:44
None #1502
Thanks Sanddrag. Would this controller work on a standard EduBot?
Unread 02-08-2005, 23:51
If it is the 2004 Mini-RC (programmed in C) as in the IFI link above, then yes it will definitely work. We use that exact radio with ours. There are some more radios here http://robotcombat.com/marketplace_rc.html but the one I lined to earlier at Tower Hobbies is the cheapest I have found. It is 4 channel. You can use two radios, or get one radio with more channels if your project requires more functionality than four channels can provide. You can think of the 4 chanel radio as two dual axis (x and y) joysticks with no buttons.
Unread 02-08-2005, 23:58
None #1502
Ok. Thank you very much. Like I said, this is just a practice robot. Once the rest of my team gets most of it finished, we are going to make a mini Omni Bot. That will prove to be interesting to program as my first real program.
Unread 03-08-2005, 03:50
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
On the serial port for the FIRST transmitter/receivers pin 1 is +5 volt power right?
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 03-08-2005, 08:06
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
If you just want to be able to supply some inputs to the robot controller you can use the application available for download here: members.cox.net/seanwitte. The RC must be connected to the PC via a serial cable, but its good for basic testing. The UI has four "virtual" joysticks and 8 switch inputs and received 8 bytes, 16 bits, and 6 ints of feedback from the RC. You can also capture and plot up to ten of the channels.
Spotty Radio Communications! Mr. Lim Control System 12 22-02-2005 20:47
radio problem Anton Control System 1 19-02-2005 12:22
Internet Radio Stations cibressus53 Chit-Chat 2 26-10-2004 00:28
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
