Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 03-08-2005, 10:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Simple telescope (lenses)
So that's really all there is to it? Let me see if I've got thsi straight. If you go down the telescope, here's what happens. The big objective lense gathers light and eventually focuses it to a sharp point. Then the light leaves this point invetered and the rays are going away from each other to make an enlarged image. Then a short distance away, they hit the eyepiece, where they are re-bent to be straight and focused again.
Does that sound right?
simple mistakes birdman Rules/Strategy 8 10-04-2005 23:32
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
help with simple project erikh98 Technical Discussion 8 27-08-2004 11:24
Simple things you can do to make your bot/team perform better KenWittlief General Forum 21 01-04-2004 15:11
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
