Go to Post "The secret to success is to acknowledge that you have limits, but to never acknowledge that you have reached those limits." - lady_raidan [more]
Unread 04-08-2005, 15:25
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
(SolidWorks) Create Sketch Points Around Curve
Can any SolidWorks experts out there answer this question?
Given something like a circle sketch (or something more complex), how do you define it by placing, say, 2000 points around it. I could array 2000 lines around the centerpoint evenly and then click at every single intersection to create a sketch point, but that's not what I'm looking for. Thanks.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 04-08-2005, 15:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: (SolidWorks) Create Sketch Points Around Curve
My SolidWorks trial ran out so I can't really look at it but is it possible to do a "circular pattern" of just points?
Unread 04-08-2005, 15:31
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Let's say you created some crazy squiggly shape that is blob-like...
Unread 04-08-2005, 15:38
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
That's a pretty crazy sort of thing you want to do there, I must say. I'm fairly certain you can't actually tell it to define points in that sort of way. If I needed to do this for some reason, I'd draw the circle, then draw a radius in the circle, make the radius a construction line, and circular array it 2000 times. If you constrain one end of the line to the center point and the other end to the circle itself, you don't shoot your parametric abilities to heck like you would if you made a chord line and arrayed it. So you can still change the diameter of the circle at will. You could change the number of points as well, but it would most likely screw up anything you had constrained to the points.
Thinking about it, you could probably just create a single point and do the same thing.
I'll have to look into other ways to do it for more general shapes when I get home.
Unread 04-08-2005, 16:56
President, VEX Robotics, Inc.
Yan,
First, to define a circle only 3 points are required. Any more points than that and your circle is over defined. In SolidWorks 2005, you can select the circle sketch tool and in the property manager on the left side you can select "perimeter creation". This will use 3 points to define the circle.
For a complex curve you can use the 2D spline tool and insert as many points as you like. You can add points after the fact, too. The points can all be dimensioned to constrain the spline. Also, SolidWorks uses Visual Basic in the background for macros. You can automate the process by putting coordinates of points in an Excel spreadsheet and using that table to generate your spline.
-Paul
Unread 04-08-2005, 19:29
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Paul, thanks for the help. I'll try it out tomorrow at work and see if it works. This is for work and the SolidWorks model will be converted to another, older program's settings, which requires features to be defined by points rather than radii (radiuses?). Otherwise, I wouldn't imagine who'd want to do this
Unread 04-08-2005, 21:20
I would imagine the point creation is taken care of in the conversion process in this case. Atleast something like this usually happens in my experience. For instance, when you save as a .STL file, you have options for the resolution and how it finely it segments curves into lines.
2004 Season for Fantasy Football, FIRST Robotics league Alex Cormier Chit-Chat 155 29-12-2004 13:12
A new season, a new task Koko Ed Fantasy FIRST 18 19-12-2004 13:21
Fantasy FIRST suggestions for next year Joe Ross Fantasy FIRST 39 14-04-2004 01:13
Fantasy Football! EddieMcD Chit-Chat 176 30-12-2003 18:30
