Go to Post I don't just participate in FIRST, and it’s not part of my life. FIRST is my life. - sciguy125 [more]
Unread 05-08-2005, 06:36
sunnyrx7turbo sunnyrx7turbo is offline
sunnyrx7turbo is an unknown quantity at this point
Can the pic controller send the data to pc?
I am the newbie for pic..now i have a problem..
can the pic controller send the data to pc via USB?
if can..can anyone tell me the method?
thz a lot
Unread 05-08-2005, 12:27
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: Can the pic controller send the data to pc?
thz a lot
I'm not sure if you're on a FIRST team or not, but technical discussion of PIC processors on this forum is generally limited to the Innovation First FRC control system, which uses the PIC18F8520. Still, many knowledgeable people are here that might be able to help you.
That said, a few PICs have on-board USB, but I believe most are low-level serial like RS232 and I2C. Since the control system we use doesn't support USB, we generally use USB serial adapters like this.
Hope this helps, can you post more about you're trying to do? Good luck!
Unread 05-08-2005, 13:14
Thanks for ur advice..
my project is need wrtie a program to receive the signal or data from external device,then send the data we retrieve direct to pc via USB port.Our PIC controller model is DM163025.
So,i need to know that whether there have method to do that,since the model know only support to download program from PC to controller via USB.
Anyway,thanks for the help and advice everyone gave.
Linking two controllers together - the how? part DanL Programming 12 15-10-2003 22:17
2004 edu controller (PIC) is out! caffel General Forum 13 09-10-2003 23:02
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Developing a standard Jack Scouting 23 03-01-2003 23:04
