Go to Post Did you inform McMaster Carr that up to 3000 FRC teams would all be attempting to acquire a very specific spring ASAP all on the same weekend? - cgmv123 [more]
Unread 02-08-2005, 23:23
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Gas R/C car
I have already built one robot that i am still improving upon but i needed more speed...
so ever since this winter i have wanted to build a gas r/c car and haven't really had the money up til about now because i will soon be getting a better job.
i look at some of the systems in the T-maxx cars and saw how simple they are, i will most deffinately be using the steering system which is the simplest i have found anywhere and I am thinking i would like to make it have suspension and maybe 4-wheel drive so it can have fun off road too.
and i need some suggestions and ideas, i dont really have a size in mind i would like to make it much larger then the T-maxx cars beacause i am going to us some sort of small gas motor from either something like a chain saw or weed wacker, or something else which ever i can find cheaper. But i dont really have any specs on any weed wacker motors because i can find them, any one know the average torque and RPMs for one?
i dont know the wheel size, i make make it interchangeable so that on the road i can put large wheels on to go faster and then smaller ones for off road
another HUGE problem is the differential, anyone know of any inexpensive solutions? i was thinking of using one off of a T-maxx which i would figured would be ok because they r hardened steel and made for high motor speeds if they are used in cars that can go 60 MPH+ would it be fine with a weed wacker
if(most likely) i use a weed wacker motor i need a centrifugal clutch to use with, which would means i also need the idle speed of the weedwacker i will use, so anyone know of good places to get a centrifugal clutch for cheap?
Unread 02-08-2005, 23:32
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: Gas R/C car
I actually need help on "pepping" up a stock $5 car from Family Dollar. Right now we have the biggest motor we can fit in it. What else can we do to make this thing super fast? The car is a Chrysler Powerbook or something like that...we already stripped the decals and started painting it. So, what else can we do?
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 02-08-2005, 23:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gas R/C car
What exactly are you trying to do? Take a T-Maxx and make it have a bigger chassis with a bigger engine? What is the end goal of this project?
If you are looking at a wheedwhacker engine, I'd suggest you look at a chainsaw one instead. Unlike wheedwhacker engines, they usually have the pull start in the rear so it will be easier for you to adapt something to the shaft in the front. For a centrifugal clutch, I know most gas chainsaws have one, but other than that I'm not sure about any details since I don't have a gas chainsaw. It is possible (not certain, but you could try) a gokart style centrifugal clutch would work if you made a properly sized keyed shaft (5/8" or 3/4") to adapt to the engine.
These wheedwhacker and chainsaw engines can usually get up to around 7-8K rpm (provided they are the 2-strokers).
Unread 02-08-2005, 23:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
why wouldnt i be able to adapt somthing to the shaft if the pull start was in front? and a chain saw is madd expensive : ' (
and the end goal is like a custom gas powered rc car, u can compare anything to a tmaxx, a fordeplorer is a huge tmaxx with more power and more space
Unread 03-08-2005, 00:01
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Gas R/C car
I have a question. Just how big do you plan on having this robot be? And if you want just a fast robot, I'd recommend just using a T-Maxx chassis and an engine that comes with the RTR version. It also has an E-start so it's easier and more reliable than a pull-start like on other engines. The only thing I'm wondering if you're going to throw in a weedwhacker motor or a chainsaw motor is can the drivetrain parts of a 1/10 scale monstertruck handle it? You might go through a lot of the gears for the 2 speed gearbox that it comes with, unless you're going to make a custom gearbox for it and I say KUDOs to you.
You wouldn't have to modify the chassis much if you're going to use the RTR T-Maxx, maybe just to add a microcontroller to it, because all you would need to control are the servos, one for throttle and one for steering. If you want something bigger to work on, maybe you might want to check out the Traxxas 1/6 scale Monster Buggy.
Unread 03-08-2005, 00:24
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: Gas R/C car
you should google giant scale r/c, there are a bunch of companies who build cars and trucks powered by zenoah gas ignition engines. you would be suprised how cheap you can get a glow engine for.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 03-08-2005, 01:21
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
i never sed i am going to use the transmission from the t-maxx i sed i am going to use the differential and buying a tmaxx to rip apart would defeat the purpose of me even doing it cuz i would be spending like 400$ on a couple parts that i can get on ebay for like 30$ and i was saying that i may use the differential cuz i was asking everyone else if they think it would work so i dont know if it would work either
Unread 03-08-2005, 03:16
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Gas R/C car
I currently own a both a 2.5 T-maxx and a Lost LST, both nitro powered.
I am pretty sure a T-maxx transmission will blow to pieces stock, if you plan on using an engine more power than what comes with a stock T-maxx.
They can also blow to pieces if put under load such as cornering and braking.
I have never seen one in action or in person, but I bet a differential from one of these would hold up:
http://www2.towerhobbies.com/cgi-bin...I=LXGMP7**&P=0
Either that or you could spend some cash buying all metal parts for a T-maxx differential. The only things that are metal in a T-maxx differential are the gears and shaft, everything else is plastic and very prone to breaking. That setup might work, but it all depends on how much stress you put on it.
Look around I am sure you can find a differential much better than a T-maxx differential.
You might be able to find something on this site http://www.harm-racing.de
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 05-08-2005, 16:19
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
i was looking around and instead of like a weed wacker or chain saw motor i would buy a 47cc or 49cc pocket bike motor off of ebay, now that would give it speed and off-roads capabilities
Unread 05-08-2005, 16:42
Re: Gas R/C car
Just make sure you know what you are getting into. This project isn't going to be cheap. Especially when you start getting into 1/4 scale servos and stuff like that.
Unread 05-08-2005, 16:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
i kno, i figure maybe 700$ but it will go way faster then the ones you can buy for 700$
Unread 05-08-2005, 16:57
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
the only problem is the differential, i figured for now if i cant find anything that i dont HAVE to have one i can just u a solid rear drive shaft until i can make one, seeing as how it is really easy to make one with one have 5 gears, but then i have to figure out what to do for lubrication because chances are it will just be mounted on a 1/4" aluminum plate
Unread 05-08-2005, 16:59
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
and i need to make a rool cage when i make the main frame so that i dont brake it the first time i take it out and try jumps,
my friend owns like 5 acres and they are all in his back yard and he goes dirt biking there so the jumps will be fun to test it on
Unread 05-08-2005, 17:57
Re: Gas R/C car
If you are going to take jumps, you should make the car as light as possible, but don't sacrifice durability. For the role cage, do you have access to a welder? Even just a small arc/stick welder should work. If not, maybe an oxy-acetylene torch for brazing? If not, then perhaps a simple roll bar (as opposed to a full cage) would suffice. Find some tubing that has a hole the right size to tap for a machine screw/bolt. Then bend a hoop (leave the ends straight) and tap both ends. If it is aluminum, it is possible that you could just cold forge the threads using a Grade 8 socket head cap screw.
What is the car going to be based on other than the pocketbike engine?
Basically, what off the shelf parts are you using and what are you making yourself? I'm insterested in exactly what the frame, suspension, driveline, and steering are going to be and roughly what the overall dimensions are going to be.
Unread 05-08-2005, 20:03
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Gas R/C car
pretty much everything will be made by be or i will be peying someone to machine, we have a cnc mill at skool that i can use that i will most likely make parts on.
suspension-
i am not sure on yet, i may wait til after the wholething is made to have suspension so Iknow what to buy, in terms of strength because i dont want suspension on it fomr a mountian bike if it is like 100 poyunds, buit i also dont know what the force for max compression is on the T-MAXX suspension is.
Drive Train-
-either a weed wacker, chainsaw or pocket bike motor
-when i make suspension i will have to make drive shafts with U-joints in them, or buy alot from socket sets
-the main drive shaft i don't know yet because i dont have a engine, when i buy one i will update
-the differential, i may not start out with one because of the intial cost
-to control the throttle i will use a servo
for a clutch i will use a centrifugal clutch made for the motor i will buy(mostlikely the pocket bike motor), the only problem is i think they only come with a sprocket on the output, which wouldn't be a problem but those sprockets are weird because i bought one once and it didnt fit #35 chain, so i will have to machine that down to a cylinder and weld somthing on or just weld it to the sprocket so that it is a longer perimeter which will make the stress on it less and which will reduce the over all stress because of the larger diamter
Brakes-
i doubt i will have them on when i first finish it but WILL eventually add for saftey
Control-
i will use a T-maxx/E-maxx/Traxxas model TQ3 am wire controller, the only problem is that i dont know the maximum range of it, this will be the first item i buy because if i have no way on controlling it there is no use in making it
Steering- the steering will be based on the T-maxx/E-maxx/Traxxas steering system, i may start out with off the shelf parts but will eventually upgrade to machined aluminum part because of the forces on turning at high speeds, especially on uneven ground and in the dirt/sand
Frame-i will most likely use 1/16" walled 1/2" square steel tubingfor the first frame then upgrade once everything is in working order and i have added what i wanted( i have like 30 feet of it in my basement and i made my robot frame out of it which remind you i must is very very strong)
then i will probally use 1/8" walled 3/4" walled square aluminum tubing or use one 1/4" plate to mounted everything too kinda like the T-maxx frame but thicker
i have access to a welder on at home, which is a 90 amp chicago electric gasless flux cored mig welder(i know it doesnt sound like much but I welder the frame for my robot with it and it works wonderfully not to mention the frame hasn't broke yet after me jumping on it and throwing it around
also at school I can use our dynasty 200 tig welder
also one last thing I wanna add, is that once skool start i will most likely have an internship at a machine shop where i know the owner, i would have had it last year but our conselor is a different story
anything else you would like to know?
World's Fastest R/C Car, anyone? Billfred General Forum 75 05-08-2005 12:56
pic: ChiefDelphi On The Run UlTiMaTeP Extra Discussion 31 20-05-2005 21:56
What do you all drive? Frank(Aflak) Chit-Chat 67 18-11-2004 23:49
How long can car idle on a tank of gas? sanddrag Chit-Chat 11 13-09-2004 12:46
What is Car Nack's Corner? Joe Johnson Car Nack's Corner 1 09-01-2004 21:44
