Go to Post Our club visited the Seattle Regional this week and they all have the FRC bug now. May God have mercy on our souls... - Rick TYler [more]
Unread 06-08-2005, 02:06
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
gyro substitution
i have seen people on here doing expirement with balancing robtos and they wanted to know if you could make 'segway robot' with just an accelerometer and no gyro and of coure the answer was to us distance sensors, but of coure those won't work as well on surfaces that are not level.
so i got to thinking and wondered if you could use a accerometer to measure rate of angular change by some how starting a timer when the angle starts to change and check it every X seconds and then compute it for how fast it was changing angles and then update the speed of the robot or unit? would this work? could this possibly work? would it bogg down the processor too much? would you need a co or sub processor just to handle that? would it be easier and simpler to do? less expensive, yes but how effiecient will it be?
if you can't do that can you make a program for distance sensors with some kinda of switch to measure when it is level and then adjust the distance each sensor should be at? so it will work on a slope of X degrees?
and for a balancing robot that does use distance sensors how do you know what motor speed to use and length of time they are on so you dont go past the desired angle u wish to be at?
Gyro Calibration ImmortalAres Programming 1 07-06-2005 13:29
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
arm-limitting gyro PD loop producing some strange results ZZII 527 Programming 8 16-02-2005 02:30
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
