Go to Post Your robot is trying to talk to you, all you have to do is listen. - Al Skierkiewicz [more]
Unread 07-08-2005, 21:33
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Parallel to serial converter
is there something you can use to make a 8 bit parallel to a serial signal for a parallel LCD screen,
to be more clear i need something with a serial input but with a 8 bit parallel output
I COULD use a shift register but i dont know how good that would work since the parallel output updates as the input update, would i be able to use a shift register or should i use something else.
i dont know how good i described it but i am trying to convert a parallel lcd module to a serial, tell me if i need to redescribe the problem
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
QBASIC, Parallel Ports, and Windows XP Venkatesh Electrical 1 21-03-2004 19:07
