Go to Post What is this "non-robotics life" of which you speak? :ahh: - Karibou [more]
Unread 13-02-2005, 17:09
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Autonomous Code trouble
can anyone find whats wrong with this code ?
static unsigned int t;
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
t++;
if (t <114)
pwm01=160;
pwm02=160;
i know this should run indefinitely....and that is the goal right now......but everytime i compile everything and load the code.....it doesnt work
(this is the autonomous code i wrote for the user_routines_fast.c area where it says autonomous code here..)
any help would be much appeciated
please reply or email me at Johnbk14@gmail.com
Unread 13-02-2005, 17:33
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Autonomous Code trouble
one possible problem is that you never set variable t, and you never have it do anything after the 114 loops, like neutralizing them.
Try this:
static unsigned int t=0;
t++;
if (t <114)	//edit(added): runs Forward for 113*26.2ms = 2.9606s
pwm01=160;
pwm02=160;
else
pwm01 = 127;
pwm02 = 127;
...etc...
- from B B frank
Unread 13-02-2005, 18:19
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It would be helpful if you'd include your entire user_routines_fast.c file. Looking at your code sample, for example, you're missing a closing '}', but I know it must be there, because you code compiles. So... the entire file would be helpful.
Unread 13-02-2005, 20:54
Be more specific. What do you want it to do? What does it do instead?
Unread 14-02-2005, 08:09
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
you know how to enable autonomous mode, don't you? you have to put a jumper somewhwere- don't remember where.
you could try enabling it manualy:
autonomous_mode=1;
I didn't check that, so it might do something else instead.
Anton Povzner, head&tail of team 1581 programming team... and that's just one of the many reasons for us to loose seriously
Unread 14-02-2005, 16:17
Ssbfalcon's Avatar
Ssbfalcon Ssbfalcon is offline
The beta version
AKA: Arthur
FRC #1546 (Chaos Inc.)
Ssbfalcon is an unknown quantity at this point
Send a message via AIM to Ssbfalcon
That looks like the answer. Be sure to trace variables used in loops and if's etc if you find that things aren't working the way you want them to.
Also, for autonomous mode testing and such, having a mock competition port is very useful. Firstly so you can activate autonomous mode with the flick of a switch, and also if that goes crazy, you can disable it by pressing the disable button.
Don't Lick Dry Ice!
Unread 16-02-2005, 21:51
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
as people said, make sure that your actually going into autonomous mode. Look at this link:http://www.ifirobotics.com/docs/comp...guide-reva.pdf. if you want to make something to be able to kill your bot or put it in autonomous mode
Harker Robotics:1072
http://www.harker-robotics.org
Unread 21-04-2005, 21:55
i figured it all out.....i should have posted a long time ago..... i misplaced the line of code that declared my variable..... int t=0;
t++;
that should have been in a different location.......thanks for all the advice/help/links and such
Thanks again everyone,
John
Unread 08-08-2005, 21:08
Guys thanks for all the help and advice during the season.
I have become more familiar with C and C++ now. And advice i have for other rookies like myself is to stay away from Global Variables.
Unread 09-08-2005, 19:47
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
I ask my students to add a 2 letter prefix to variable names in order to keep the different scopes and types of variables sorted out. We don't touch the IFI variables, just the custom code we create...but that helps to identify IFIs code, as well:
First character:
t - type
m -data member of class, struct or
union (non-static)
s - static class scope
g - global scope
a - argument, non-reference
r - reference argument
l - auto local (temporary storage)
Second character:
n - number/scalar, non-enumeration
e - enumeration scalar
s - struct
u - union
a - array
p - pointer
So if we wanted to add a static int "t", it'd be snt and snT. If global, gnt or gnT or if used solely in a function lnt or lnT. It looks a bit awkward, but it really helps me when I'm code reading and debugging.
Eric
Don't PANIC!
S. P. A. M.
Unread 11-08-2005, 01:09
Kyle T Kyle T is offline
waiting for next season...
FRC #0810 (Mechanical Bulls)
Kyle T is an unknown quantity at this point
I wish that MPLAB was more like Visual Studio 2005, there'd be much less complaining. If you forget to initialize a variable, it tells you with those nice underline spellcheck uses in MS-office. You forget a semicolon? VS2005 tells you right away at the end of that line, in a way that doesn't make you have to click a button in an alert box. It helps you get into good habits.
Unread 11-08-2005, 13:57
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
First character:
t - type
union (non-static)
g - global scope
Second character:
s - struct
u - union
a - array
p - pointer
Eric
You should've told me that 3 years ago Eric, I would've understood your code much more then, I always wondered why you labeled your variables like you did. :-p
Chopsaw? Chopsaw.
Unread 22-09-2005, 18:44
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Exclamation Re: Autonomous Code trouble
Even though the comment says that it is a 26.2ms Loop area (I think it was 26.2?) it is in fact 40ms. The autonomous loop runs in 26.2ms space, but your code actually runs in 40ms space.
What I do to keep from getting confused is this:
#define second 40
#define tenth_second 4
//IFI code goes here
unsigned int autonomous_clock;
if (autonomous_clock < ((2*second) + (4*tenth_second))
pwm01 = 254;
pwm02 = 254;
else
pwm01 = 127;
pwm02 = 127;
++autonomous_clock; //adds 1 to the autonomous_clock count
I forget if the default code uses pwm_max, pwm_min, or pwm_neutral, but my code did. I merely use pwm_max as 254, pwm_neutral as 127, and pwm_min as 0
Hope this helps.
Unread 22-09-2005, 20:14
Electrical Engineer
Rookie Year: 1995
Originally Posted by RIgnazio
Even though the comment says that it is a 26.2ms Loop area (I think it was 26.2?) it is in fact 40ms. The autonomous loop runs in 26.2ms space, but your code actually runs in 40ms space...
Roger,
Your code is correct but your statement about 40 milliseconds is wrong:
40ms * 40 = 1.6 seconds
40ms * 4 = 0.16 seconds
However, if we assume that the loop cycle is 26 ms we get:
26.2 ms * 40 = 1.048 seconds
26.2 ms * 4 = 0.1048 seconds
Trust the math...
Mike
Mike Betts
As easy as 355/113...
Unread 22-09-2005, 20:17
Thanks for the clarification on that, no wonder my autonmous values seemed incorrect
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
