Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 12-08-2005, 12:32
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Parallel to serial converter
a basic stamp also has an lcd command, i would to use the athena too if that is the one you are talking about, i would learn both, because in real life you have to know a wide range of products
A BASIC stamp is really easy to use, i was just wondering something
but back to the athena microcontroller, what language does it program in
and views on the AVR from atmel?
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
QBASIC, Parallel Ports, and Windows XP Venkatesh Electrical 1 21-03-2004 19:07
