Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 15-08-2005, 10:29
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
How can you pick up a hula hoop?
Hey all,
I was sitting at my house thinking about different field objects and good grabbers, and i was wondering, how would YOU pick up a hula hoop if it was part of a game challenge? i guess that what you would need to pick up the hoop and place it on top a tall platform (the hoop would have to be placed so that it is parallel to the ground)
Unread 15-08-2005, 10:42
Eugenia Gabrielov's Avatar
Eugenia Gabrielov Eugenia Gabrielov is offline
Counting Down to Kickoff
Eugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond repute
Re: How can you pick up a hula hoop?
This is a really interesting concept. I have a few considerations.
Are we looking at a normal light plastic hula hoop? Those break easily. A robot would have to manipulate it with some kind of small arm structure in this case. If the hula hoop is in the ground, the arm would have to be able to reach down and grab it as such. If it's hanging, that's a lot more like this year's system and just grabbing it and locking it. I think a robot arm like 234 (for those who saw their efficient lock system) would be excellent if the hula hoop was hanging. Such an arm could be manipulated to reach down and clasp the hoop off the ground if it fell.
If the hula hoop is more sturdy, that gives a bit more leeway as to the power of the arm and the manipulation of the hoop. Also, what is the size parameter? Hula hoops are actually kinda big, and while light, a robot lifting many of them would have to plan out how to not let them get caught on things.
Just some thoughts, sorry for the lack of mechanical technicalities.
Northwestern University
McCormick School of Engineering 2010
Computer Science
Team 461 for life!
Unread 15-08-2005, 10:43
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Hm... a hook. If the hula hoop was standing up, a hook would definetly work. Laying down, you'd have to make sure it can slip under the hula, but pretty much the same.
If the hook can extend far enough to get the end of the hula hoop over to the far edge of the platform, you're good.
Unread 15-08-2005, 10:48
Rich Ross
for my idea, the hoop would be on the ground. maybe even picking up a hoop from a stack of hoops...
And the hoops would be prolly aluminum and not all cicular shapes...
Unread 15-08-2005, 14:06
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
What about some kind of wedge system? Insert something into the middle of the hoop, expand it and then wedge the hoop with it.
http://www.mikesorrenti.com/
Unread 15-08-2005, 14:10
Rich Ross
That could work, but it might have to expand to get pretty large. And remember, this would have to be raised such that the hoop could be placed somewhere, say 8 feet in the air. Maybe more...
Unread 15-08-2005, 15:02
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
The distance that the gripper would have to expand would not necessarily be very large.
In this paint sketch, the gripper configuration resembles a peace sign, with the shorter of the two arms expanding inward and outward - only a minimal distance. The actual expansion distance would not be very large - the only large thing about this arm is its height, which is not very restricted considering that the height limit for the robot (this year anyways) is a generous 60".
Here's an idea of how this gripper would look like on a robot, when the robot was picking up the hula hoop from the ground:
In the above picture, the "peace sign" gripper would center itself inside the hula hoop on the ground. Then, the two extending arms of the gripper (the short arms of the peace sign) would expand outwards (using pneumatics perhaps?), and the hula hoop would become "wedged" on to the arm.
Here's what it might look like in its upright position:
This is what the robot might look like after the hula hoop has been "wedged" between the two expanding arms and the one non-expanding arm. After being "wedged", it can be lifted up and placed anywheres. There are a whole slew of possible arm mechanisms to go along with this gripper - in the picture, I drew in two rotating joints that would be used to position the hula hoop (of course, the configuration of the arm mechanisms would depend on the game task).
If any of these ideas don't make sense to you, let me know and I will try to make it clearer. The idea behind this gripper is that there is minimal expansion required to "wedge" the hoop. Because the two extending arms of the gripper are angled, they don't have to stretch the entire diameter of the hula hoop. The third (non expanding) arm provides enough resistance for the two expanding arms to create an effective wedging mechanism.
Nice idea Mike - I really like it! Expanding off of other peoples ideas is fun.
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 15-08-2005, 15:40
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
nice job jaine..
my mind right now says wedge it up and have a small grabber..
back to packing though...
nice brain teaser for all of us though
Unread 15-08-2005, 16:21
Rich Ross
seems like an okay way to pick the thing up, but inefficient for putting on top of the platform, especially at 8 feet in the air. What about some sort of clamp that grabs it like a person would wiht their hands, and just put that on a telescoping lift?? i feel that might be a little harder to grab with, but more efficient as far as the height of the arm goes...
Unread 15-08-2005, 16:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Good idea. If you could grab it tight enough, you could even make the clamp rotate so you could bring the hoop to horizontal, or even further up to vertical so you are then holding at the bottom rather than the top.
Unread 15-08-2005, 21:55
Rich Ross
thank all of you for the ideas and proving that there are several ways to do it. Keep the good ideas coming...
Unread 15-08-2005, 22:06
c-squared_2006 c-squared_2006 is offline
Student Leader / Scout
None #1015 (Pi Hi Samurai)
c-squared_2006 will become famous soon enough
I may sound like an idiot but here goes... I'm horrible at explaining my thoughs...
We can take a combo of ideas, primairly the wedge idea and the clamp/gripper idea. We can come up with a gripping system that some how uses the wedges to 'lift' the hoop so the grippers could "tighten" and obtain better control of the hoops. I have a design in my head, it's just that I can't describe it. Don't worry if you don't understand my ramblings... sorry
Unread 16-08-2005, 01:26
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
I found the best answer to these type of question is to do it yourself and observe. From watching myself do it a couple times you need a gripper that comes from both sides (so as not to push it away) gets under (thin "fingers") and lifts the hoola hoop off the ground as it picks it up. Something like the claws in those stuffed animal game boxs would be perfect though don't give it that third finger that makes it so hard to use!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 16-08-2005, 04:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'd do something along the lines of 175's 2005 gripper.
you have a wedge shaped piece to get under the hoop, and then a piece that rotates down and clamps onto it, allowing you to pick it up and keep it parallel to the ground
2001-2004: Team 100
2006-Present: Team 254
Unread 16-08-2005, 07:25
Ya know, back when I was a kid and hula hoops were new on the block...A quick way to pick it up from the ground was to step on it, slide your foot back and the friction rotates it right into your hand. And you thought that was a hacky sack trick.
The awesome NON-INVITE FANTASY FIRST Draft Tim Delles Fantasy FIRST 73 29-04-2005 08:25
How does your team pick presidents/ captains? Marygrace General Forum 30 29-04-2003 22:37
Does any team pick up small BALLS???? archiver 2001 5 24-06-2002 00:53
Top seeds pick.... archiver 2001 6 23-06-2002 23:12
How many balls can you pick up?????????? CMC General Forum 6 14-02-2002 21:40
