Go to Post I always get a little stressed as arm operator, especially with Paul Copioli standing behind me screaming at me. - JohnnyB [more]
Unread 16-08-2005, 02:11
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
pic: Team 100 CALGames Robot
Unread 16-08-2005, 02:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Team 100 CALGames Robot
I like it. Looks like a very rigid arm structure and a very effective setup. It seems like you will be doing multipositioning with the pneumatics so I assume the compressor will be running full time. Is that a motor in between the pneumatic cylinders? If so, what is it for?
Also, it looks like you are doing a 6 motor drive. Big thumbs up to that!
I'm curious as to why the double wheels? To be sure you are applying the power of that 6 motor drive?
PS. Is this thing built yet?
Unread 16-08-2005, 02:24
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
The arm is actually an interesting setup. The vandoor motor drives the arm via chain & sprockets, and the pneumatics drive a cam which also drive the arm -- in short it's a motor powered, pneumatic-cam assisted arm.
And yep, the double wheels are to get as much traction as possible.
So far the transmissions are about 95% built.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 16-08-2005, 02:50
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
I like it alot, especially the way each side has its catamaran wheel setup (never was partial to rectangles). Im wondering about pneumatics though. I try to stay away from them because of weight, lack of fine control, air leakage, (even on the best system you get this), and the potntial damage of a tube getting snagged. Unless their is a specific reason you want to use them i would say stick to motors. Is it possible to do a close up of the wheel assembly? I would love to see it! Nice work.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 16-08-2005, 03:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
My guess would be because they only have two window motors, the van door, and a globe to work with.
It already needs pneumatics to shift, so they can't avoid the weight penalty of the accumulators or compressor, anyways.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-08-2005, 15:06
Cory is right. We decided to do it the simple mechanical way, difficult control way. It will take quite a few sensors and soleniods to control this, but it is just tedious, but not overyly complicated. And I'm not the programmer, thank god.
As for those interested in specs:
High: 15 fps
Low: 8 fps
12 skyway 6" wheels with wedgetop tread, riveted on
Chassis: 1x1 .125" wall all around
Arm support: assortment of 1x1, 2x1, 3x1, all .125" wall
Arm: 2" tubing, .125" wall
Armor: .125" aluminum plating, all around
Motors: 4 CIMs, 2 FPs, 1 van door
Pneumatics: two 6" stroke, 1.5" bore, one .5" stroke, .75" bore
weight: 110 lbs (without battery)
Unread 16-08-2005, 15:52
6 motor two speed? Shweeet! I have GOT to see this once you get some pics. I sooo wish we were going to Cal Games, it would be a perfect matchup for our HexaMax 6 motor 2 speed drive.
I'm glad someone else was crazy enough to make one this year.
Yours looks pretty small/light. Are you doing an additional chain reduction outside the box or is it all in the box?
PS. When/where is Cal Games going to be anyway?
Unread 16-08-2005, 17:12
24 Hours of LeMons?
Yep, there's a pretty large chain reduction from the gearbox to the wheels (12:60).
Also, torque figures: about 107lb-ft in low, 67lb-ft in high.
And I think Cal games might not be happening
Maybe I can make the team go to an SCRRF off-season event.
Unread 18-08-2005, 03:45
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Unfortunately, the smart money has it that CalGames has slid into the dumper this year. There's still a possibility that there will be something short of a full 2005 FIRST competition.
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
