Go to Post MORAL: Always wear safety glasses when you're putting on your safety glasses. ;) - Joel Glidden [more]
  #31   Spotlight this post!
Unread 04-05-2005, 19:37
Robomaniac928's Avatar
Robomaniac928 Robomaniac928 is offline
FRC #0063 (Red Barrons)
Robomaniac928 is an unknown quantity at this point
Re: COTS Parts made just for FIRST Robots
i would definatlybe interested in a FIRST shop i think i whould carry gearboxes shafts wheels sprockets chains and and any other part that would be nessasary to build a good drive train and i twould be great if they cariied omni wheels because i dont know about anyone else but i have been searching for a while but i cant find any that are what i need. it would have to be reasonably priced with a quick ship time as well
  #32   Spotlight this post!
Unread 04-05-2005, 19:41
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Robomaniac928, have you looked at AndyMark?
-Paul
  #33   Spotlight this post!
Unread 18-08-2005, 21:21
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Originally Posted by cdr1122334455
An adaptor for that you could use a servo to switch the AndyMark tranny instead of the Pneumatic shift. Also a servo shifter for the Dewalt Transmission too. I'd price them about $30-$45 range depending on the price of the design and the servo.
my team used a servo for shifting of the dewalt transmission, we found out how in one of the white papers
  #34   Spotlight this post!
Unread 18-08-2005, 22:16
Gdeaver Gdeaver is offline
FRC #1640
I'd like to see a add on optical encoder module for the KOP transmission. All that would be needed would be a gear meshed to the output gear with a 1/4" shaft. There are optical quadrature encoders that can be had for less than 1/2 the cost of the Grayhills. A code wheel with a dual photo interrupter module could be done for even less. Add a coprosessor to handle the counting. Make it programmable so that it could be set to pull a pin low after so many counts. Also the current count and calculated velocity could be sent out to the TTL serial port either by query or every so many ms. Add some interface code in the default code and there would be no reason for any team to sit and do nothing for autonomous next year.
  #35   Spotlight this post!
Unread 18-08-2005, 22:45
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
The one thng i have trouble getting (at least the right type) that a number of teams do is tread. It would also be nice to see specialty materials like square carbon fiber rods. it costs just over $120 to make a 20 ft length with i believe 1" per side. Actualy its not hard to do and if you contact me ill list some suppliers and tell you everything you need to know to make some. Im not telling Why i know how to though!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
  #36   Spotlight this post!
Unread 18-08-2005, 23:48
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
What you didn't really add was that it never worked particularly well. The servo barely had enough power to shift the transmission and sometimes it would get stuck out of gear. If it were done again, it would require two servos shifting each DeWalt (at least).
Matt
  #37   Spotlight this post!
Unread 23-08-2005, 14:49
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Matt
You want to be careful with that. It's popular method with RC model airplanes (the really big ones, like 33% Extra 300's) to gang two or more servos to make a really big control surface move (I have most often seen this in the rudder, though there are often more than one servos driving each aileron) and I have seen some articles about how they can fight each other if not calibrated correctly, reducing battery and servo life. There are COTS parts that keep them from doing this, but I don't know how they work.
Just something to look into.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
New member, new team, questions. Frank(Aflak) General Forum 21 14-12-2002 06:59
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
Consider the following... archiver 2000 15 23-06-2002 22:40
New FIRST Ruling -Wow the implications Mike Martus General Forum 51 07-02-2002 22:03
What advice would you give? Jessica Boucher General Forum 8 02-12-2001 07:10
