Go to Post More teams will want to join, peers who are not on the team will understand the program better, television will become interested in FIRST again, sponsors will be easier to get, cancer will be cured, the Israelis and Palestineians will live in harmony, and we will have world peace. - Andy Baker [more]
Unread 04-06-2002, 12:55
lockportcew lockportcew is offline
#0641 (Mission Specialists)
lockportcew is an unknown quantity at this point
Post chapita motor problems
We are entering our third year as participants in the FIRST competition. We're looking at the possibility of using the chapita (sp) motors as the main drive source for our 'bot, but we are having difficulty with the motors pulling too much current and popping the 30amp fuses. We are using a chain drive system with a 12 tooth drive gear directly attached to the motor shaft to a 20 tooth driven gear. This is attached to an axle with another 20 tooth gear which is in turn attached to our wheel shafts. Any suggestions? Any help would be greatly appreciated.
Unread 04-06-2002, 23:14
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Hey, well all i remember from our robot is that we used the chiwapia motors and a 60 amp breaker if you need more info contact Wayne C. on the cd forums
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 05-06-2002, 11:16
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
It sounds like your gearing is too high.
Look in the White Papers for Team 716's design. It uses the cluster gear to bring the rpm's to something more manageable.
The motor turns at 5,500 rpm free speed.
The gear ratio's are:
motor/cluster = 9?/44
cluster/output gear = 16/60
This gives an output speed of 300 rpm. We geared this 2:1 giving 150 rpm to our 9" dia Skyway wheels.
You can use chain to attain the same output directly from the motor but it takes more room.
Good Luck
Andy
