Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 23-08-2005, 16:03
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Light Sensing Robot
to test my programming skills with a PIC(when i get it) i was gonna make a light sensing robt, to go to the brightest spot, or the darkest, but i dont know how i would sense the light, i could use a photoresistor or photo transistor but that would measure the like where the sensor is not out away from it
for example if the robot was in the shadow outside it would sense the shadow not the sun light
Unread 23-08-2005, 16:17
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Light Sensing Robot
Parallex is you one stop shop! Seriously they have exactly what your looking for. I was thinking about using one of their ultrasonic sensora on our robot..
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 23-08-2005, 16:26
A photoresistor is a good option. You'll need to mount it so that it has a "view", like putting it at one end of a tube with the other end open and pointing away. It'll act something like a one-pixel camera. If you place the tube on a servo you'll be able to scan the scene in various directions before deciding which way to turn the robot. If you mount it solidly to the robot you'll have to turn the whole thing to look for light and dark.
Multiple sensors with different "views" can make it easier to decide which direction to move at any given moment.
Unread 23-08-2005, 16:31
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here are some suggestions:
1) Use two photo resistors facing the same direction, separated by a piece of foam a couple inches long, or anything else that will block light. Measure the difference between the two cells to determine which side is brighter. Adjust your steering to go toward the brighter side until the values of the two cells are equal (within a certain window or dead band). This will allow you to steer toward light.
2) If neither cell is seeing enough light to determine which way to steer, like your shadow scenario, set the program to run a searching pattern. A spiral outward works well and is simple to implement.
Both of these suggestions will take some experimenting to find what values work well. Photo resistors are notorious for not being matched, so you should grab extras to sort through to find a set that are close. Then you may need to build a custom circuit to give you a real good match, slightly modifying the resistance of one leg over the other of the sampling circuits.
Oh Bummer. Alan beat me to the punch while I was typing.
Unread 23-08-2005, 22:22
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
wouldn't that not work becuase doesn't a photoresistor measure the light touching it?
Unread 24-08-2005, 09:57
If you put the sensor inside one end of a tube, what touches it is the light from what the other end of the tube is pointing to.
Unread 24-08-2005, 10:47
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I dont know if i am just confused or what because I am really good with electronics, but if the sensor is in on end of the tube and the other end has light at it(lets say a 3 inch tube) would the light that is touching the sensor the shadow from the tube?
but i will just take your word for it and try it
Honda Motor Co's humanoid robot Mirza95vx Math and Science 26 10-04-2005 12:42
YMTC: Bluabot "Descores" Red Tetra Natchez You Make The Call 34 09-04-2005 15:02
How much do you design before kickoff? Allison K General Forum 19 07-12-2004 21:32
Public apology from myself (Team 830) Don Wright Rules/Strategy 13 14-03-2004 22:02
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
