Go to Post You are beautiful. - Joe Johnson [more]
Unread 25-08-2005, 00:21
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Current reversed on compressor spike controller
Originally Posted by mechanicalbrain
The spike is literally not receiving a signal.
If you haven't already tried another spike, do so. But, we had this problem too. It took us days to figure out. You're probably not putting the PWM connector in right. It might go all the way in, but the pins might not actually be in the connector. Sometimes, we would even get only one or two of the pins in.
Just to make sure though, pull the connector out of the spike. Test it for voltage between ground and the appropriate signal pin. It should be a solid 5V. If you have that right, then I probably found your problem.
Actually, I just reread your post...
we got a response from the compressor but all that happened is the fan made a twitch (I'm guessing the motor switched polarity) once every second
Do the voltage test still to check your code. But also pay attention to the LED once you plug it back in. Orange is off, red is reverse, green is forward. I also think that the spike makes a clicking noise when it changes direction (I can't remember). You might also want to put in a meter instead of the compressor to make sure that it's getting a solid 12V.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Current Sensor Joshua May Programming 6 12-02-2004 10:48
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
