Go to Post I don't like to tempt the gods of inspection on items like this. - MrRoboSteve [more]
Unread 05-06-2002, 11:16
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
It sounds like your gearing is too high.
Look in the White Papers for Team 716's design. It uses the cluster gear to bring the rpm's to something more manageable.
The motor turns at 5,500 rpm free speed.
The gear ratio's are:
motor/cluster = 9?/44
cluster/output gear = 16/60
This gives an output speed of 300 rpm. We geared this 2:1 giving 150 rpm to our 9" dia Skyway wheels.
You can use chain to attain the same output directly from the motor but it takes more room.
Good Luck
Andy
