Go to Post Start respecting your mentors more or they might just leave. - Eric Bareiss [more]
Unread 26-08-2005, 12:12
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: 2 wheeled balancing robot
Originally Posted by K.Shaw
equation not equasion
haha that is what i get for doing it late at night
Unread 26-08-2005, 14:21
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
i am looking to do it with small gear motors or servos, MAYBE i am not sure how much power i will need so i may use CIM or drill motors and i dont know what i will use for a controller because i dont know the speed yet, the size will be about 2 feet tall or less and it will be a robot that will not bbe riden on i will eventually make it so i can control it like adding an offest to set the "balance" a little off so it will drive one way while it is "balanced"
would i be able to use folmulas from the inverted pendulum problem? because there motrs would be moving it and the gyro would meaure the tilt just as a pot on a inverted pendulum would
Pre-Rookie Teams - The How To Keith Chester General Forum 6 17-09-2008 00:28
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Self-Balancing 2 Wheeled Robot Mike Robotics Education and Curriculum 25 02-08-2005 15:12
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 19-01-2005 11:35
THIS TIME TEAM 438 BALANCING ROBOT archiver 2001 1 24-06-2002 01:01
