Go to Post You can never have enough figurative language. - Travis Hoffman [more]
Unread 28-08-2005, 16:56
Morenoh149
Posts: n/a
Question Can you explain the diameter measurements used in bullets, wire and nails?
just thought this might intrest some ppl in the technical department.
http://home.howstuffworks.com/question260.htm
Unread 28-08-2005, 18:35
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Can you explain the diameter measurements used in bullets, wire and nails?
Well, i know that gage 1 wire is not engough thickness to power the lights i installed in my car . (hint: i now have burned carpet)
Unread 28-08-2005, 18:42
What they don't tell you is that the bullet info is only good for rifles and pistols. Shotguns have their own system. (The number, or gauge of a shotgun is the number of lead balls the size of the barrel it takes to equal a pound. So a 12-gauge is larger than a 20-gauge.) And some rifles have odd sizes and numbers. (I know of an 8 mm magnum.)
This site has only basic info, if you want more, try their links or do an Internet search.
Unread 28-08-2005, 18:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I find that very hard to believe. Welders (and fairly large high current ones) often use 1 gauge wire. Did you leave out a zero and mean 10 gauge wire? If not, what exactly are the lights you have and what exactly happened with this wire?
