Go to Post I love you ChiefDelphi times! - Amanda Morrison [more]
Unread 29-08-2005, 00:21
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Electrical Component Kit
i am good at electrical stuff like desgining circuits and all that but I am also very good at bread boarding but i don't get to do too much of it on the account of me not having the right parts. So i decided i was gonna make and electrical component kit for myself so i dont gotta repeatedly order things from places that have a manditory 6$ ordering fee. so i would like to know from everyone what things I should order in terms of any kind of components.
i already have in mind:
And gate
Or gate
inverter
Nand gate
Nor gate
Xor gate
Xnor gate
resistors
capacitors( should i get very small sizes like in mylar?)
LEDs
LED displays
Speaker(already have like 9)
7805 (TO-220 package) (does anyone know any other power regulators i can use in the 7805's place or that could be of use?)
and umm.... anything you wanna add
also if you would like to add anything that we could put in if someone were to do this as a team that would also be helpful
Unread 29-08-2005, 01:44
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Electrical Component Kit
What's your price range?
Your list seems to indicate that you will be doing digital. In addition to the gates, there's some higher level digital stuff you might find interesting (flip-flops, mux/demux, counters...). Are you considering doing some analog work at some point? If so, you might want to consider some analog ICs, particularly op-amps. Analog would go nicely with your speakers.
You also didn't mention anything about tools. Are you already outfitted for electronics work?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 29-08-2005, 01:49
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I would recommend a 555 timer IC. More info.
555 Timers
Edit: Mike beat me to it by about 5 seconds. Oops.
Unread 29-08-2005, 03:22
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by sparksandtabs
...i already have in mind:
And gate
Or gate
inverter
Nand gate
Nor gate
Xor gate
Xnor gate...
Did you know that each of these gates can be constructed from a NAND gate(s)? Also, you might consider looking into a Field Programmable Gate Array (FPGA) development board like this one and learning a Hardware Description Language (HDL) like VHDL or Verilog.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-08-2005, 09:27
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
For my various ECE classes, I've had to buy 2 different kits - one was the development board Kevin posted a link to and the other was one containing resistors all the way from 10 ohms to 10 Mega-Ohms, along with caps from 5 pF to 300uF, various IC's including op amps, 555 timers, simple gates, LED's, pots, various transistors and regulators, a breadboard and a wire kit for it. Its very useful, but I can't say that I would have been tempted to spend $80 on it myself if I wasn't forced to get it for the class. Its made by this company - http://www.esssales.com/esssales/custom-lab-kits.html but the parts are custom ordered to what WPI wanted for their classes. The FPGA board Kevin posted a link to is extremely useful, because of the nature of FPGA's you are not limited by specific "hardware layers" (not sure if that is the right word really, but you are not limited to an RS-232 serial port or ethernet port), you can implement anything on it until you run out of logic space.
Unread 29-08-2005, 12:50
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
o yeah i forgot to include alot of simple stuff like the 555, fliop flips, latches, and pots.
Unread 29-08-2005, 14:56
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
All I can say is get a very, very wide variety of resistors. I do the same sort of thing, and I am always using resistors, and some of the time, I need a specific resistance, and its very handy to have the right one lying around.
Oh, and spare wire. It's your friend. I also keep other things in there, such as hex inverters, shift registers, and 5v regulators (even a servo or two if I am working with that sort of thing) but definitely resistors.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 29-08-2005, 19:05
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I forgot to mention that Mouser has component kits. I think that the 5% carbon film resistor kits are in the $20 range. There are also kits for inductors, capacitors, transistors, diodes, connectors, and some other things.
Version: 3.12
Unread 30-08-2005, 07:35
Each designer has a their own list of stuff. Since mine is mostly analog...
a handful of NE5534 OpAmps
LM317 Voltage regulators (they can be programmed for different outputs with two resistors)
a handfull of electrolytic caps, 10, 100, 500 mfd and some .01 .1 ceramic caps
A nice bench power supply, either buy or build, two outputs, 0-15 volts @1 amp at least.
Can never have enough push button switches
A nice Fluke VOM, spend the money you will use it for the rest of your life.
Catalogs and data sheets if you can get them.
Load up on 1N4148 diodes they are cheap
1N4001 diodes if you plan on doing much in power supply design
A nice drawer cabinet to put everything in. If you can't find it you will never use it.
2004 Electrical Component Rule Rationale phrontist Electrical 31 06-01-2005 22:12
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
A Real Transformer? (the robots, not the electrical component) Nick Seidl Chit-Chat 2 02-04-2004 12:23
Looking for unusual electrical component JamesJones Electrical 11 08-07-2003 20:36
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
