Go to Post Teams must bring their own water. Water must consist of a low viscosity and at it's maximum width must not be larger than 12 in. - Bkeeneykid [more]
Unread 30-08-2005, 09:35
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: PIC Programming
As far as I know, the JDM will program all serial programmable 12F, 16F and 18F PICS as well as some serial eeproms. Here's a schematic for the "fully loaded" version:
http://www.josepino.com/3/
You can get all the parts for less than $10.
Edit: I forgot to mention that the JDM will also work for in circuit programming (you don't have to pull the chip out of your circuit). However, it eats 2 of your I/Os.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Book on C programming - suggestions? wun Programming 18 14-01-2005 00:12
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
Programming Code themaxim Programming 10 07-01-2005 13:07
