Go to Post It does it automagically. - David Kelly [more]
Unread 25-08-2005, 19:23
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Current reversed on compressor spike controller
I would like to thank everybody for their help. We finally got everything up and running. What ended up happening was a series of unrelated events that caused only the compressor to stop working. First our pwm cables to the had been damaged and kept causing trouble. At this point it worked 50% of the time. After replacing these the compressor stopped working all together. This is when we started this post. All of a sudden it decides to work this morning (still don't know why?) after extensive testing with a multimeter but it wouldn't turn off!! Our code to regulate it didn't seem to work. After testing the pressure sensor we found that the pwm for it was plugged in but it wasn't getting power! Well thats when we remembered that not all our pwms were long enough to reach the controller so instead of splicing them and soldering two together we had just connected them and taped them and the splice had come apart! After fixing that and reinstalling our original code we finally got it to work properly.
In summery Ive learned two things. One: make sure everyone next year knows the proper way to wire (and make sure were super neat). Two: I REALLY hate pneumatics!
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 25-08-2005, 20:18
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
It seems that Murphy decided to pay you a visit.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 26-08-2005, 10:02
Originally Posted by mechanicalbrain
...I REALLY hate pneumatics!
Why? Everything you mentioned breaking was electrical.
Unread 26-08-2005, 10:29
A good way to connect two PWM's end to end is to tie a knot and then tape the connectors and knot.
Unread 26-08-2005, 10:55
That's true of just about any in-line connector. We regularly tie overhand knots in extension cords and serial cables when we have to use more than one. That way the tension on the wires tends to pull the connections tighter instead of apart.
Unread 05-09-2005, 07:33
Yeah thats what im going to do now. And the reason i hate pneumatics is that murphy would have a field day with them. Their are too many weak points in a pneumatic system that can cause the entire system to fail. At least if you loose a drive motor it only hampers you (this is dependent on the robot)!
Current Sensor Joshua May Programming 6 12-02-2004 10:48
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
