Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 04-09-2005, 16:22
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Grid computing software
I've been looking for grid computing software for a friend of mine because he wants to link 2 g4 mac computers together through the network card and use the combined processing power to make video editing tasks go a little bit faster. I found a few programs to do this (i used wikipedia) but I'm wondering if anyone else has done this before. if you have, what programs did you use?
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 04-09-2005, 18:18
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: Grid computing software
Look no further, If you have tiger or panther it is built in
Xgrid
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 04-09-2005, 18:22
[527]phil's Avatar
Alumni
AKA: Phil
Thanks for the help, but he doesn't have either one of those, and I'm not just looking for it for mac, i want to see if i can use it on my windows machines (imagine playing Americas army of Battlefield 2 with triple the processing power!! *drools*)
Unread 04-09-2005, 18:41
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Step 1. Tell him to throw away his Mac and get a PC. (A whole Mac is almost as evil as the Windows OS)
2. Format your hard drive and your friend's.
3. Install Linux on both machines.
4. Learn to use and love the penguin.
5. Read the the following howtos, particularly the first one.
http://howto.x-tend.be/openMosix-HOWTO/
http://www.ram.org/computing/linux/linux_cluster.html
6. Enjoy your new Linux cluster that automagically detects new nodes on the network.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 05-09-2005, 12:20
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Well, technically you aren't talking about grid computing. You're actually just referring to cluster computing (grid computing implies geographically distributed systems as opposed to just several systems sitting next to each other).
Now, beyond definitions, you may get some faster video processing using a cluster. Or you may not. When dealing with clusters, the key ratio you look at it computation to communication. If there's too much communication compared to the computation, then you'll actually slow down by using multiple computers.
In actuality, it's rather hard to get a speed up by using clusters. The communication required provides a huge hit on your performance maximization. This is the main reason that we haven't seen many commercial level clusters. It's usually restricted to things that are termed "hard problems" (N-body gravitation, cracking encryption, engineering simulations, etc.).
The vast majority of clustering setups these days no longer do implicit clustering. There are some software packages that do things in that manner but explicit clustering is more preferred now. What this means is that software has to be aware of clustering to take advantage of it instead of it happening automatically. The reason for this is the communication problem described above: the software needs to know if things are going to other machines so that the communciation doesn't swamp things.
That said, I would highly doubt you'd ever get video games to work in a cluster situation. For one, most are single threaded and don't have their work partitioned such that it could even take advantages of multiple processors, let alone multiple computers. There's simply too much communication required compared to the amount of processing.
I'm doing my thesis in this area so I have a bit of knowledge.
Matt
Unread 05-09-2005, 16:34
[527]phil's Avatar
Alumni
AKA: Phil
Thanks for the information, but I'm looking for Grid computing software, the system you just explained is parallel computing. As of now i can do mathematical formulas and code lists, But what i really want to do is use both computers for video editing. Right now it takes about an hour (with dual processors) to compile all the special effects and stuff, I'm just trying to make it go faster.
Unread 05-09-2005, 16:50
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Maybe I don't understand your question, but from what I understand of how all this works, you do want a cluster. If I understand you correctly, you have 2 computers and you want to distribute a time consuming task between them. If your software supports multiple processors, then it's probably multithreaded, so cluster computing should work. Depending on the exact setup of the cluster, each node is treated as a processor. Essentially, you end up with a giant multiprocessor computer.
Edit: From what I understand, "grids" and "clusters" are functionally the same, but physically different.
Version: 3.12
Unread 05-09-2005, 18:59
Grid computing is a type of parallel computing. It basically is just a bunch of geographically separate computers that operate in parallel. You really are looking for a cluster even if you don't know it.
I'd look into your video editing software and see if it supports clustering. For it to really work, the software itself really should support the clustering.
Matt
Attention engineers...What type are you and why? Paul H Career 95 05-04-2007 14:38
software software software archiver 2001 5 24-06-2002 00:21
