Go to Post On these forums, there are so many people that we see working all of the time to try to help teams out, and just overall good people. To everyone who does that, thanks. - miketwalker [more]
Unread 07-07-2005, 01:18
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
IFI Loader Reloaded
For the last couple weeks, I've been working on writing my own version of IFI Loader. The major improvements are being able to read the flash and being able to "tag" it. By tag, I mean putting some information at the end of the flash so that you know stuff about it. Normally, after it's written to the controller, all information about it is gone. You have to rely on memory and testing to find out what it is and who put it there. At the moment, the tag contains the programmer's initials and the time it was written (I'm open to suggestions about what else it could have).
This is only a preview release so that I can get some feed back about it. It has enough functionality to be used full time instead of IFI Loader, but I wouldn't do that just yet. There are many bugs and many of the widgets in the GUI don't actually do anything yet (and will probably be removed anyway). I also have to do some code clean up to get it ready for a real release.
All development of IFI Loader Reloaded has been done in Linux. It uses Qt, so you should be able to compile the GUI on Windows, Linux, and Mac with the appropriate software from Trolltech (http://www.trolltech.com/products/qt). The only problem with other OSes is the serial port code. Right now, it's only written for POSIX systems. I think you can use Cygwin to compile it on Windows, but I haven't tried it. Although, it'd be nice if someone would write a Windows port (information to do so is in the package).
You can temporarily get it here:
http://ratlab.dyndns.org/loader/ifi-reloaded_qt.zip
It'll only be there for this preview release. I'll find a more permanent home for it at some point. Pretty much, I'd just like to know what you think of it. Suggestions, comments, wishlist...
Notes:
-the serial port is currently hardcoded to /dev/ttyS0
-various bugs
-the menu and toolbar are pretty much decoration (little functionality)
-also see README
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 07-07-2005, 06:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: IFI Loader Reloaded
Hey! Now that's cool. This goes along great with Eclipse!
(Or heck, even the FIRST Contact Database)
Unread 07-07-2005, 16:41
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
Looks nice.
I do not have access to the controller right now, but will test when I get it again.
Unread 19-08-2005, 00:24
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Alright, it took me awhile, but I'm back. Now I have a windows port. Through the miracle of compiler directives, the same files will compile on windows and linux. I'm almost ready to make a release (probably in the next few days), but I need some help. I'm not set up to compile a static binary for windows. I can get a windows binary, but you'll need Qt (and probably MinGW also) to run it. I don't think library issues are a problem on linux because most of them will already have Qt anyway.
Windows folk seem to shy away from compiling programs from source so, I'm looking for Windows Qt developers that can get me a distributable binary. You'll need Qt3 (Qt2 might work, but I know for a fact that Qt4 won't - I'm working with 3.3.4). I'll give you the source, you can compile it and send me the binary. I'll figure out how to distribute it. I don't need anyone at the moment, I just want to know who I can get help from.
Version: 3.12
Unread 22-08-2005, 12:28
Electrical Engineer
AKA: Phil Baltar
FRC #1351
IFI Loader Reloaded 0.1.0
http://ratlab.dyndns.org/loader/ifi-...d_qt-0.1.0.zip
You can download Qt 3.3.4 from SourceForge
If you're using Visual C++ and plan on installing Qt from source, I'd appreciate it if you compile Qt for static libraries and send me your ifi-reloaded binary.
Version: 3.12
Unread 22-08-2005, 12:38
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
I'm running Qt - Windows Dev. with static libraries & can take a shot at it for you.
EDIT: Your most recent post reminded me of the fact the I'm running Borland-5 - Will try to resolve that.
Unread 22-08-2005, 18:18
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Very cool. I'm currently the lead developer for the Linux ifi-picloader and its textmode enhancements. This looks very awesome. What's the license on it?
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 22-08-2005, 19:25
Electrical Engineer
AKA: Phil Baltar
FRC #1351
It's GPLed. The Qt license is the GPL, so any works using it have to be also (almost anything I do will be anyway...).
And thanks for ifi-picloader. I used it as a reference when writing this program.
I wrote this such that it can be used for command line also, but I haven't written the command line interface yet. The GUI is my main priority. The guts of the program will work independent of the interface. As long as you instantiate the primary class and call the right functions (with correct parameters), it'll do it's job.
I forgot to mention the highlights of this version:
The program "tag" contains a 15 character space for a name (intended to be some kind of program name), 3 characters for the programmer's initials (intended to be for the person that clicks Write to Flash), and a timestamp. The tag is written to the last 64 bytes of program flash. I used 64 bytes becuase I wanted to make space for future versions. If the program occupies that space, the tag won't be written though.
I also included a terminal window (like the annoying one that pops up in IFI Loader). One enhancement that I added is the ability to start and stop it. Sometimes, we use it for debugging, but it scrolls by so fast that we have trouble reading it. My terminal window also has to be called manually (I haven't decided if this is a good thing or a bad thing yet).
With the ability to read the program flash, I added a save feature. It takes what it read from the flash and writes a hex file with it.
There's also a verify option when you write (off by default because it's a little time consuming). After it's done writing, it reads the flash to make sure that everything is correct.
It's still hardcoded to /dev/ttyS0 (COM1 on Windows).
Version: 3.12
Unread 22-08-2005, 23:46
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Very nice. Off-season I'll take a look at the code, (perhaps port it to my favorite language Python with PyQT support), and make it the new Ifi-pictools
John Dong
Unread 01-09-2005, 22:13
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Ok, I have a static Windows binary. (Thanks for the offer though, Jack.) To get it however, I needed to make version 0.1.1. It's now ISO C++ compliant and thus compilable with VC++. No other changes though.
Windows binary
Linux/Windows source (not tested on Mac, but might work)
Depending on your system, you might need the VC runtime libraries:
msvcp71.dll
msvcr71.dll
Unzip the files you get there and drop the dlls in C:\Windows\system
Version: 3.12
Unread 05-09-2005, 20:57
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
hello...
i have two questions, one of which is even on topic. has this been tested with the vex programmer? the thing has its own wee little pic built in, whether for obfuscation or actaual added functionality i don't know.
the off topic query is this. are there instructions for the braindead available detailing the installation of mcc18 under wine? is it possible to do this without windows isntalled on the linux machine? i have a dying laptop with windows and mcc18 installed and would like to get the compiler moved over to my desktop before the laptop breathes its last, (literally, the fan has gone intermittent). i have no experience with wine, the pic compiler and pinball are the only two windows programs i use and pinball isn't really important enough to me that i much care.
anyway i'll slurp a copy of the picloader dowline here and see if it'll recogize my toy.
thanks...
Unread 05-09-2005, 21:35
Electrical Engineer
AKA: Phil Baltar
FRC #1351
It hasn't been explicity tested with the Vex kit, but it's compatable with IFI Loader. I think Vex uses IFI Loader, if so, then it should work.
As for mcc18, it runs fine with wine. I haven't tried MPLAB though. Just copy the mcc18 folder to your Linux machine. The Makefile from 245 is also good to have. There's more information in this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=36377
Version: 3.12
Unread 21-10-2005, 22:12
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Hi,
First, thanks for this great software. I couldn't test it right now because I don't have an RC with me, but is there a way to copy data from the terminal window? A big problem I have with the original loader is I cannot download such data to analyze it with, say, Matlab or Excel
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 22-10-2005, 07:00
Programming User
Originally Posted by Manoel
Hi,
I can't test it, because I don't have the controller with me, but I'm willing to bet that both the original and the QT loader terminal windows use ctrl-c to copy.
Unread 22-10-2005, 12:06
Electrical Engineer
AKA: Phil Baltar
FRC #1351
I haven't tested IFI Loader, but I'm pretty sure copy works with mine.
Version: 3.12
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
Um... IFI Loader Ryan M. Programming 3 14-01-2005 21:15
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
