Go to Post FIRST is about family, making new friendships, belonging somewhere, doing something you love, and finding out what your real love is in life, so when you're old and wrinkly you can look back at high school and say "This is when I found myself." - Winged Wonder [more]
Unread 08-09-2005, 16:55
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
DC Voltage indicator
I'm looking for an indicator lamp that will indicate when a battery voltage drops below a certain voltage setpoint (i.e. 10 volts). I need to keep some engine electronics alive during transport of an engine with a battery and need an indicator that is green, or steady, or something when the voltage of the battery is above the setpoint, put changes to red, or flashes, or something when the voltage drops below the setpoint to alert someone to throw a charger onto the battery.
Anybody have any ideas? We found one, but the green color was so dim, you couldn't really tell it was on unless you were looking right over it...not good for a test cell.
Thanks. I know this isn't FIRST related, but I hoping someone here can help...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 08-09-2005, 17:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: DC Voltage indicator
Now this is probabely me being crazy but you might want to google DC voltage indicator . The first result was this http://www.gibsonteched.com/ck005.html .
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 08-09-2005, 17:50
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Are you looking to buy one, or is building one an option?
My knowledge of electronics is far more limited than I would like it to be, but what I would probably do is use a regulator to get you a fixed 5V value, and then use a comparator with your 5V reference and a resistor voltage divider on a line coming off the battery, if the 5V line is higher then the battery is below your value, and if its lower, then the battery is still good.
Unread 08-09-2005, 19:31
Electrical Engineer
Rookie Year: 1995
I agree with Brian. Building is better. A resistor divider as the - input to a comparitor (LM211?) IC and a zener diode as the + input with an LED on the output should work fine.
Mike Betts
As easy as 355/113...
Unread 09-09-2005, 07:20
Don,
Maxim has a line of battery monitor ICs and they are available from Digikey. A simple LED will not give the indication you are looking for without additional circuitry.
Unread 09-09-2005, 07:52
Don Wright's Avatar
FRC #0469
Thanks for the help guys.
Designing and building one is an option, but only if I can't find an already designed solution. There are a lot of voltage level IC's out there and "kit" solutions, but it needs to be a very complete and robust solution. It will be living in a test cell environment and needs to be very reliable. So, it would require circuit board design, prototyping, beta units, final production...all things I would like to avoid due to costs and time.
I know it requires more than just a simple LED, but I didn't know if anybody here had any experience with something that already exists. The unit we found was a nice large LED, housing made of machined aluminum, with simple jumpers on the back to select the voltage level, and small terminals for connecting wires. It is very nice, and cheap (<$40), but just is not bright enough. We are in discussions with the supplier to try and recitify, but I'm just trying to find other options to fall back on.
And mechanicalbrain, I've googled everything I could think of believe me. The circuit you show would not work because it would require modifications for panel mounting in the box... Thanks for the suggestion though.
Thanks again for the help everyone... I appreciate it...
Product Manager
Voltage Regulator Robby Electrical 5 18-01-2005 07:50
OI Voltage JAH Electrical 7 12-11-2004 20:01
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Output voltage in PBASIC diego25 Programming 7 31-01-2002 22:50
