Go to Post Before anyone accuses FIRST of being in the pocket of the sponsoring corporations, they might spend a minute and a half to actually apply some of that critical analytical ability that we are supposed to be demonstrating as educated engineers. - dlavery [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 08-09-2005, 23:11
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: please help me! its an egg drop contest
Full sheets of newspaper? I think they would make a good parachute.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 08-09-2005, 23:14
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Alternate on that: Use one sheet of newspaper for the actual parachute, and have another as a "basket" underneath the egg to cusion its fall.
Unread 08-09-2005, 23:16
jess jess is offline
jess is an unknown quantity at this point
yeah thats what i was thinking but what type of basket? would a cone or square or what be the best? also should i have a hole in the parachute?
Unread 08-09-2005, 23:22
Electrical Engineer
AKA: Phil Baltar
FRC #1351
If you made a cone for the basket, it could act as a cushion if it crumples correctly. You'd have to somehow make sure that it falls point straight down. As for the whole in the parachute, I think you'd need to run some experiments. I'm not well versed on parachute theory, but I think that the hole would add extra stability if it's the right size. The size of the hole, and its necessity, I think would depend on the mass distribution of the entire system. If the egg is heavy enough, it should be able to stabalize itself.
Version: 3.12
Unread 08-09-2005, 23:24
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I will try to explain the way I did it in my engineering class, I was given the same material (2 sheets of newspaper) and 12" tape (not as much as I want). Professor asked me to create one without a parachute.
I made a "cone" out of one sheet of newspaper (like a rocket). Then I used the 2nd newspaper (cut them in pieces and made balls which I called "foam around the egg") to make a shell for the egg, so it doesn't break. The point of this was for the sharpest corner (if you are looking at a V ... you want the bottom of V to drop first) to touch the ground first. The egg was safely covered somewhere in the middle of the V. Once it hit the ground, of course the bottom of V shape messed up. But the egg was fine. I dropped it 3 times, once from 3rd floor, once from 4th floor, and once from 5th floor (not to mention with the same egg). It was a success. Since then, I never felt the urge to use parachute anymore.
Good luck with your project. I hope I was able to help even a bit (I hope you understood what I was trying to explain). If you need any help, please don't hesitate to send me a message on chiefdelphi or Aim.
Originally Posted by Billfred
One of the sheets has to be a parachute. This is non-negotiable for success--there's no way to do it without slowing down the egg.
I do have disagree with you Billfred on this topic. But I am not saying that you are wrong. You have your own way to do things, I have my own. I have made one (the way I explained) and it worked (it didn't break even after dropping from 5th floor), I didn't slow the egg down, it dropped as fast as it could. But the egg didn't even have a crack. As I explained above, You do have to make sure that the basket/cover/shell/whatever you want to call it is "comfy" enough for the egg to sit.
Agreed Phil. That is the key to this project. You HAVE to make sure that it falls pointing straight down. The sharp corner has to hit the ground first.
Unread 08-09-2005, 23:29
Billfred's Avatar
Billfred Billfred is offline
I stand corrected--this is news to me.
Unread 08-09-2005, 23:43
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Hmm...I'm now tempted to try to organize an egg drop contest for the Silicon Valley Regional...
Edit:
I just remembered that SJSU's ISE department has an "egg deceleration" contest. Link to PDF in upper right corner. The regional is held in the SJSU event center. But the department's competition is in November apparently... Maybe I can pull some strings. Well, maybe not seeing as I don't know any important people...
Version: 3.12
CD's Unofficial Caption Contest #53 Billfred Games/Trivia 34 17-07-2005 16:53
CD's Unofficial Caption Contest #50 Billfred Games/Trivia 29 26-06-2005 16:39
The Egg Drop Project Joe Matt Math and Science 1 20-05-2005 13:05
nother egg drop contest SchmitTheNordic Math and Science 11 30-04-2004 23:25
Egg Drop Contest Matt_Kaplan1902 Math and Science 27 02-02-2004 14:45
