Go to Post Come on how can you not be excited about IRI! - richardp [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.00 average. Display Modes
Unread 05-09-2005, 13:30
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Gyroscope Code
For those who might be interested, I've just posted updated gyroscope interface code for IFI's robot controllers. The code has been significantly reworked to use the new ADC interface code, which allows the programmer to use other analog sensors alongside a gyroscope without affecting the performance or operation of the gyroscope. In addition, significant performance improvements can be realized using the new oversampling and deadband features. The code can be found here: http://kevin.org/frc. As always, if you find a bug in the code or a problem with the documentation, please let me know.
-Kevin
Here's the readme file:
The source code in gyro.c/.h contains a driver and supporting
software to interface a variety of inexpensive gyros to your
robot controller. This software was tested with Analog Devices'
ADXRS401EB, ADXRS150EB and ADXRS300EB gyros. Data sheets for
these devices are included. By default, this software is
configured to work with a ADXRS150EB gyro, sampling at 800Hz,
downconverting to an update rate of 50Hz by averaging sixteen
samples per update. These parameters can be changed by editing
gyro.h and/or adc.h.
Version 0.5 of the gyro interface software has been altered
to use the ADC interface provided by adc.c/.h. This change
allows the programmer to use additional ADC channels for other
analog sensors without affecting the performance or operation
of your gyro. See the documentation included with adc.c/.h for
information on how to use this new functionality.
Another new feature is the ability to specify a measurement
deadband centered about the gyro bias. ADC measurements within
this deadband will not be used to calculate the gyro angle or
angular rate. This feature can have a significant impact at
minimizing short-term drift just after a bias calculation has
taken place. To use this feature, follow the instructions
embedded within gyro.h.
This source code will work with the Robovation (A/K/A EDU-RC)
robot controller and the FIRST Robotics robot controller.
Wiring-up the ADXRS401EB, ADXRS150EB and ADXRS300EB gyro
evaluation boards is straightforward: Grab a PWM cable and cut
off the male end and strip the three wires back a centimeter
or so. With a low wattage soldering iron, solder the white wire
to the RATEOUT pin, solder the black wire to the AGND pin, the
red wire to the AVCC pin, and finally connect a jumper wire
between the AVCC and PDD pins. Plug the female end into one of
the robot controller's analog inputs. These gyro evaluation
boards can be purchased from analog devices (www.analog.com),
and Digi-Key (www.digikey.com). Another great source for
Analog Devices gyros is SparkFun Electronics (www.sparkfun.com).
For optimum performance, you'll need to calibrate the scaling
factor to match that of your gyro. One way to calibrate your
gyro is to mount it very securely to a hefty, square or
rectangular object. Mounting the gyro to a hefty object will
help dampen higher frequency vibrations that can adversely
effect your measurements. Place the mounted gyro against
another square object and start the included demonstration
software. To get good results, the mount must be absolutely
still when the "Calibrating Gyro Bias..." message appears on
the terminal screen. After a few seconds, the gyro angular rate
and angle will be sent to the terminal screen. If the angle
drifts rapidly while the mounted gyro is motionless, you need
to restart the software to acquire a new gyro bias measurement.
Again, gyros are very sensitive and must be still while the bias
is calculated. Once the gyro is running with little drift,
rotate the mount 180 degrees and note the reported angle. If the
angular units are set to tenths of a degree, the ideal reported
angle is 1800. If set to milliradians, the ideal angle 1s 3142
(Pi times a thousand). For every tenth of a percent that the
angle is high, decrease the GYRO_CAL_FACTOR numerator by one.
Conversly, for every tenth of a percent low, increase the
numerator by one. Repeat until you're satisfied with the
accuracy.
The included project files were built with MPLAB version 7.20.
If your version of MPLAB complains about the project version,
the best thing to do is just create a new project with MPLAB's
project wizard. Include every file except: FRC_alltimers.lib
and ifi_alltimers.lib and you should be able to build the code.
Eight things must be done before this software will work
correctly on your robot controller:
1) The gyro's rate output is wired to one of the analog inputs
of your robot controller and gyro.h/#define GYRO_CHANNEL is
updated with the analog channel your gyro is attached to.
2) A #include statement for the gyro.h header file must be
included at the beginning of each source file that calls the
functions in gyro.c. The statement should look like this:
#include "gyro.h".
3) Initialize_Gyro() must be called from user_routines.c/
User_Initialization().
4) You must select the gyro you're using from a list in gyro.h
and if needed, remove the // in front of its #define.
5) The default angular unit is milliradians. If desired, this
can be changed to tenths of a degree by editing gyro.h
6) A gyro bias calculation must take place using the functions
Start_Gyro_Bias_Calc() & Stop_Gyro_Bias_Calc() described below.
This must be done several hundred milliseconds after the gyro
powers-up and is allowed to stabilize.
7) For optimal performance, you'll need to calibrate the gyro
scaling factor using the instructions above or those included
in gyro.h.
8) Follow the instructions found in adc_readme.txt for
installation instructions.
Here's a description of the functions in gyro.c:
Initialize_Gyro()
This function initializes the gyro software. It should be called
from user_routines.c/User_Initialization().
Get_Gyro_Rate()
This function returns the current angular rate of change in
units of milliradians per second. If desired, the angular unit
can be changed to tenths of a degree per second by modifying
the angular units #define entry in gyro.h
Get_Gyro_Angle()
This function returns the change in heading angle, in
milliradians, since the software was initialized or
Reset_Gyro_Angle() was called. If desired, the angular unit
can be changed to tenths of a degree by modifying the angular
These functions start/stop a new gyro bias calculation. For best
results, Start_Gyro_Bias_Calc() should be called about a second
after the robot powers-up and while the robot is perfectly still
with all vibration sources turned off (e.g., compressor). After
at least a second (longer is better), call Stop_Gyro_Bias_Calc()
to terminate the calibration. While a calibration is taking
place, gyro rate and angle are not updated. Once calibrated, a
call to Reset_Gyro_Angle() should take place.
Get_Gyro_Bias()
This function returns the current calculated gyro bias. For
extra precision, this software internally maintains a gyro bias
value that is the sum of GYRO_SAMPLES_PER_UPDATE samples of the
gyro's analog output. By default, GYRO_SAMPLES_PER_UPDATE is
set to a value of eight in gyro.h
Set_Gyro_Bias()
This function can be called to manually set the gyro bias. For
Reset_Gyro_Angle()
This function resets the integrated gyro heading angle to zero.
Process_Gyro_Data()
This function should be called when the ADC software reports
that new gyro data is available. Ideally this should be done
within the user_routines_fast.c/Process_Data_From_Local_IO()
function. See the enclosed copy of user_routines_fast.c for
an example of how to do this.
Kevin Watson
http://kevin.org
Last edited by Kevin Watson : 05-09-2005 at 14:03. Reason: Added gyro_readme.txt text
Unread 08-09-2005, 21:46
FRC #2429
Re: Gyroscope Code
Originally Posted by Kevin Watson
...As always, if you find a bug in the code or a problem with the documentation, please let me know.
Well, I just discovered that I left one step out of the installation instructions found in gyro_readme.txt. Here are the revised instructions:
Nine things must be done before this software will work
#include "gyro.h".
4) Process_Gyro_Data() must be called when the ADC software
generates an update. An example of how to do this can be found
in user_routines_fast.c/Process_Data_From_Local_IO().
5) You must select the gyro you're using from a list in gyro.h
6) The default angular unit is milliradians. If desired, this
7) A gyro bias calculation must take place using the functions
8) For optimal performance, you'll need to calibrate the gyro
in gyro.h.
9) Follow the instructions found in adc_readme.txt for
-Kevin
Kevin Watson
http://kevin.org
Unread 09-09-2005, 00:38
Gdeaver Gdeaver is offline
FRC #1640
Re: Gyroscope Code
Thanks for the contribution to the First effort. I have a What if question.
What if First includes the EasyC environment for the 2006 season? Could your code be wrapped up and included into it? How about your serial port code?
Just curios as to you opinion if First goes down this path.
Unread 09-09-2005, 00:52
FRC #2429
Re: Gyroscope Code
Yes, the code can be ported fairly easily.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-11-2005, 22:22
gmiller_1249 gmiller_1249 is offline
#1249 (Robo Rats)
gmiller_1249 is an unknown quantity at this point
Re: Gyroscope Code
Is it possible to use a Murata gyro with the innovation controllers. If so, what changes would have to be made to the code so the controller can read the output from the gyro?
The RoboRats
Team 1249
2008 Palmetto Regional Delphi "Driving Tomorrow's Technology" Award
2007 Roboburgh Regional Imagery Award
2005 Pittsburgh Regional Winners (w/ 128, 395, and 1708)
2005 Pittsburgh GM Industrial Design Award
Unread 20-11-2005, 23:27
FRC #2429
Re: Gyroscope Code
Yes, they can be used. The code changes are very simple to make. If you provide me with a part number, I can add it to the list of supported gyros.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-11-2005, 15:21
#1249 (Robo Rats)
Re: Gyroscope Code
-Kevin
Murata ENV-05DB
The RoboRats
Team 1249
Unread 22-11-2005, 02:17
FRC #2429
Re: Gyroscope Code
Murata ENV-05DB
I've updated the gyro code to support this device. As I don't have one to test with, please let me know if you have any problems. The code can be found here: http://kevin.org/frc
-Kevin
Kevin Watson
http://kevin.org
Unread 16-12-2005, 02:17
FRC #2429
Re: Gyroscope Code
I've updated the gyro code with version 0.3 of the analog to digital conversion code. As always, the code can be found here: http://kevin.org/frc
-Kevin
Kevin Watson
http://kevin.org
Unread 10-01-2006, 23:21
FRC #2429
Re: Gyroscope Code
Well, I finally posted the ADC and Gyro code for the 2006 robot controller. Sorry about the delay, but I ran into a nasty bug that caused me to spend a few days in the fourth and fifth levels of programmer hell. The bug was in the design of the PIC18F8722 (yes, a bug in the sillicon) and I had to figure out what was going on. Anyway, the gyro code works really, really well with the gyro in the kit of parts. The accelerometers also work really well, but I need to do more testing before I unleash that code.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2006, 09:30
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Gyroscope Code
-Kevin
Thanks for all the hard work! With all the great sensors this year, how many interrupts can we use? Last year we use 4 pair of Hall sensors as quad counters, which worked well. The team is reluctant to move past success....so if I use those 4 pair, is there anything left on the 18F8722? And will using the camera code claim those interrupts as well?
Thans
Jon Mittelman
mentor
Team236
Unread 12-01-2006, 13:04
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Gyroscope Code
Kevin, you're like my own personal Jesus.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 19-01-2006, 17:59
Dave75 Dave75 is offline
AKA: Dave Blackburn
FRC #0075 (RoboRaiders)
Dave75 is an unknown quantity at this point
Re: Gyroscope Code
Well, I finally posted the ADC and Gyro code for the 2006 robot controller. ...
I just noticed that the gyro.h has DEFINEs to set the code to operate on a variety of gyro modules, but not the one that's in the 2006 KOP. According to US First's "2006_Sensor_Basic_Operation.pdf",
The actual Yaw Rate Gyro chip used on the 2006 YRG is the AD22304.
As far as I can tell, the only significant difference is the 80 degree/sec turning rate limit (vs. 150 dps on the ADXRS150).
Is there anything that needs to be adjusted in the code to handle this particular chip, or is it good enough just to leave the DEFINE the way it came?
Thanks again,
Dave
Unread 20-01-2006, 20:57
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: Gyroscope Code
I've been having trouble getting the KOP gyro to work. I attached the two PWM cables to it and installed the gryo code. The output I get from the program seems to be in no way related to what is happening to the gyro. Also, why are two PWM cables used on the gyro, is one a temparture sensor(I read that it maybe somewhere)? I'm really a bit confused and any help would be greatly appreciated.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 20-01-2006, 21:14
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Gyroscope Code
I heard the head programmer from 68 talk about this...yes, it appears to have a temperature sensor onboard. He told me it measures in degrees Kelvin, but I don't know any of the details because he is the one that tinkered with the code and got it working. The best guess we have is that the gyro readings differ based on the temp........??? Kinda strange...umm....
JBotAlan
Aren't signatures a bit outdated?
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
