Go to Post "I'd like the teeter-totter..." - Billfred [more]
Unread 18-05-2005, 19:42
ghansel ghansel is offline
my amp goes to eleven
AKA: George H.
FRC #0019 (Big Red Robotics)
ghansel is infamous around these parts
PWM inputs?
Is there any way for the RC to accept a PWM input?
Unread 18-05-2005, 19:44
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: PWM inputs?
I believe there's a way to build a small resistor-capacitor circuit that'll convert the PWM pulse in to a 0 to 5 volt charge that can read through the ADCs. You'll have to get more info from Google or someone else on here though.
Matt Krass
Unread 18-05-2005, 19:52
Bharat Nain's Avatar
Re: PWM inputs?
umm.. Why would you like to do that?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 18-05-2005, 22:29
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: PWM inputs?
Presumably you'd have a sensor that has a PWM output or something. A R-C circuit would smooth the signal out into a mostly DC signal.... However, the smoother you get it, the bigger delay there would be in the system. It's probably not terribly relevant if your PWM is high frequency, though.
For direct input, I think you'd need two digital interrupt inputs and a NOT IC. interrupts firing on the rising edge of the signal, so you start a timer when the straight signal fires, and stop the timer when the NOTed signal fires. Voila, the time of the pulse. Then you just need to calibrate the time widths to your data. And account for the delay from the NOT gate if you need real precision or something. It'd act to add a constant amount to your pulse widths, so as long as you calibrate it it shouldn't matter, though. Note that I'm not figuring out if the pulses are wide enough for the controller to measure or if there would be too many interrupts per second for the processor to handle.
Unread 18-05-2005, 22:43
AKA: George H.
Re: PWM inputs?
Thanks. I'll see what I can do, and I'll probably post my solution on here when (if?) I finish a PWM/analog converter.
Bharat: http://www.robot-electronics.co.uk/s...CMPS032004.htm
For gyro redundancy.
Thanks to all,
George
Unread 20-05-2005, 15:51
Electrical Engineer
Rookie Year: 1995
Re: PWM inputs?
...For direct input, I think you'd need two digital interrupt inputs and a NOT IC. interrupts firing on the rising edge of the signal, so you start a timer when the straight signal fires, and stop the timer when the NOTed signal fires. Voila, the time of the pulse...
Kevin, et al,
Use DIO3 and use both rising and falling edges as interrupts. Read Port B within the interrupt handler to determine which edge you are processing...
Mike
Mike Betts
As easy as 355/113...
Unread 20-05-2005, 21:08
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: PWM inputs?
Originally Posted by Mike Betts
Kevin, et al,
Mike
This is exactly how the RC decoded the modulated IR signals from 2004. The code in receiver.c would be a great starting point. Receiver.c can be found in edu_tracker.zip and frc_tracker.zip located here: http://kevin.org/frc/2004.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-09-2005, 17:57
AKA: George H.
Re: PWM inputs?
Thanks a bunch. Unfortunately (should have posted about it before) we've decided to use an integrator on a gyro instead of a compass.
Thanks anyway,
George
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
