Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 14-09-2005, 20:18
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
Error in Inventor's Guide?
I have Vex Robotics Kit. I built a 4WD skid-steer robot like the Tumbler-Bot on the web site at http://www.vexlabs.com/vex-triplets.shtml Each wheel has its own motor. I tried to follow the instructions on page E-9 but one wheel won't work if the motors are connected to motor ports 2, 3, 7, and 8. If I connect the motors to ports 1, 2, 7, and 8, all wheels work BUT when I want to turn the robot left, the robot turns right, and when I want to turn the robot right, the robot turns left. Please check into this.
Unread 14-09-2005, 22:53
John Wanninger's Avatar
John Wanninger John Wanninger is offline
FRC #1732 (Hilltoppers)
John Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond reputeJohn Wanninger has a reputation beyond repute
Re: Error in Inventor's Guide?
One thing you may want to check: Did you put a jumper in Port 15 (for tank/"23" mode), or Port 16 (for arcade/"12" mode)? Refer to page 7.17 in the guide.
"A hundred times every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving..."
--Albert Einstein
2001: FLL852 |2002: FLL20/FLL21 |2003: FLL23/FLL25 |2004: FLL14/FLL16 |2005: FVC22/FLL124 |2006: FLL3/FLL2986/FVC22/FRC1732 |2007:FLL3/FLL34/FLL56/FRC1732
2008: FLL3/FLL18/FRC1732 |2009: FLL101/FLL8963/FRC1732 ...(etc.!)
Unread 15-09-2005, 06:42
I put a jumper on Port 16.
Unread 15-09-2005, 07:10
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Did you buy a fourth motor from Vex, or are you using only the ones from the kit? The standard kit only comes with three continuous rotation motors, and one limited rotation servo. This is probably what is making the fourth wheel not fully rotate 360 degrees.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-09-2005, 07:21
After buying the Vex Robotics Kit and using it for a while, I bought another motor, another servo, wheel kit, gear kit, bumper switch kit, limit switch kit, and metal and hardware kit. I used four motors and four large wheels. The transmitter is set for "12" drive.
Survivor All-Stars EddieMcD Chit-Chat 10 01-04-2004 19:50
**IMPORTANT FIRST EMAIL BLAST**/EDUrobotics System Guide Now Available On-line!! Rich Wong FIRST E-Mail Blast Archive 2 15-11-2003 00:11
'Dummy's Guide to Starting a FIRST Team' archiver 1999 1 23-06-2002 22:59
