Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 15-09-2005, 22:38
astro1652's Avatar
astro1652 astro1652 is offline
FRC #1652 (Team Overdrive)
astro1652 is an unknown quantity at this point
Question Addressing I/O in Sections
I was wondering if it is possible to address sections of the I/O of the RC all at once. For example, I have a parallel LCD which uses 8 I/O lines for data. Thus, I want 8 pins of the I/O to be assigned either high or low at the same time instead of addressing them individually.
LCD_port = 5;
Assuming you can assign LCD_port a number of I/O pins, then telling it to assign 5 would turn on pins (bits) 0 and 2 (5 in binary is 101).
Is there anyway to do this that I am unaware of? Similarly, can I access just the upper and lower half of an unsigned int somehow? Please pardon me if these sound like n00b questions, as I am certainly a beginner in the C language.
If statement in .h file or Indirect addressing? Kevin NAV code... Chris_Elston Programming 11 14-02-2005 23:39
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
Cheering Sections at Nationals Dirty Harry Championship Event 3 06-04-2004 00:30
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Programming Port I/O MikeDubreuil Programming 4 10-02-2003 17:07
