Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 19-09-2005, 11:14
muy dificil muy dificil is offline
FRC #1611
muy dificil is an unknown quantity at this point
Ah progrmming is hard
progrmming is muy dificil
Unread 19-09-2005, 11:23
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Ah progrmming is hard
Did you have a particular problem you need help with or were you just making a general comment?
Programming isn't that hard once you get the hang of it. It has a steep learning curve like math. One day your trying to figure out 1+1, then the next day they throw x and y at you. Once you understand what x and y represent and learn to think in terms of functions, it's as easy as pi.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 19-09-2005, 11:25
FRC #1611
thanks i appreciate it
Unread 19-09-2005, 14:03
Problem with microprocessors is: they do exactly what you tell them to do
instead of what you want them to do!
Unread 19-09-2005, 15:43
You'll spend most of your time trying to figure out exactly WHAT you told it to do!
Unread 19-09-2005, 20:57
Andrew Blair's Avatar
FRC #0306 (CRT)
One muy no-no...Keep your robot battery charged when working with code. You'll have an emotional breakdown trying to find out the problem with the code, only to change the battery and find it working fine.
-Sir Francis Bacon
-Albert Einstein
Unread 20-09-2005, 10:26
TotalDomination TotalDomination is offline
FRC #1611
TotalDomination is an unknown quantity at this point
Yes, right now we are trying to program the EDU bot and having problems downloading the program to the interface.
Unread 20-09-2005, 10:40
FRC #1611
Unread 20-09-2005, 10:45
FRC #1611
Yes i know, we press the program button and turn the LED orange like it is suppose to be, but when we go to download the program onto the interface the LED resets and starts blinking again.
Unread 20-09-2005, 10:56
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I'm assuming that you're talking about the Program State LED. It will turn orange when the Program button is pressed. When you start downloading to it, the LED will flash. Is this what you're seeing? What do you see at the loader side? There should be a progress bar that shows the status of your download.
Unread 20-09-2005, 10:57
FRC #1611
No it just brings up a download error message.
Unread 20-09-2005, 11:00
Try holding the Program button on the RC down, then clicking and holding down the Download button on the loader. Release the Download button then immediately release the Program button. We've had problems in the past with older laptops not being able to download and this usually solved it.
Also, are you sure that your serial cable is good and that it is properly seated in the programming port?
Unread 20-09-2005, 14:26
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Sometimes hitting the reset button helps as well...
Unread 03-10-2005, 10:17
FRC #1611
Ok now this is not working, we switch cables, we have tryed so many times to press the program button and at different times, but it will still not program
Unread 03-10-2005, 11:26
Back after 4 years off
FRC #5279
Well I rember exactly a year ago when i was on a rookie team with the exact same problem. It gets better, since them I have learned a third programming language and written 6 different auton codes for the bot, This time last year I could do little more than program a TI 83 in a dummed down version of basic, once you get it it just keeps coming.
Now to solve your problem (or atleast to help) are you uasing a laptop or desk top. With a laptop make sure it sees the port your using, with a desktop dont bother fighting with it if you have acess to another computer use that instead, I have an HP and an Emachine at home with Identical processors, memory and operating systems, however I can only load code from my HP and not my parents Emachine, go figure. Have someone take it home and try, It seemed to me that the edu rc is far more tempermental than its FRC counter part.
Like I said I was in the same place last year, I had no mentor help and no experience (I don't know what your mentor situation is like) If you need more help then PM or Email me. I'd be more than happy to give you a hand, also if you have a phone with free long distance Id be happy to give you my cell number let me know. Email is James_brown830@yahoo.com
James
Partitioning my hard drive for redhat mechanicalbrain Chit-Chat 2 18-09-2005 07:25
Trouble booting Linux from hard drive after CD install edomus Technical Discussion 2 01-11-2004 08:03
Are you hard core or not? Joe Johnson Championship Event 7 25-04-2002 23:05
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
