Go to Post Your best friends are all team members and you could never live without any of them because robotics people are the best people. - Riverdance [more]
Unread 09-06-2002, 14:04
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Thanks for all the suggestions! PBASIC is not overly complicated (no order of operations!), so none of it should be too technically difficult. As for the 255 thing, I'm not going to check it. After all, if your code ends up producing 255's, you probably want to know! The way I've planned out the tokenizer, expressions such as x=5*y/z will be evaluated in two steps, so truncating shouldn't be an issue. The way I'm planning on doing individual bit assignments is to use different algorithms for 1 and 0. For setting a bit to 1, I will use | with everything set to 0's except the bit that needs setting. For clearing a bit, I will use & with a mask of all 1's except for the bit that needs clearing.
One more questions: has anyone ever had a need to access a specific nibble in a byte, or a specific byte in word? Is this even possible?
Wheres the list, whats the secret? archiver 2001 3 24-06-2002 01:31
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
does anyone know where to obtain a regional team list archiver 2001 1 24-06-2002 00:44
Team list & Events archiver 2000 2 23-06-2002 22:39
Suggested list of things to bring to the regionals Andrew Wyatt Technical Discussion 1 06-03-2002 14:41
