Go to Post Mind you... if your ball kicker has as much energy stored up as a trackball launcher, you ought to be able to kick balls up into the stands. - dtengineering [more]
Unread 20-09-2005, 10:52
TotalDomination TotalDomination is offline
FRC #1611
TotalDomination is an unknown quantity at this point
Trouble with Programming the EDU Bot
We seem to be having some trouble with programming our EDU Bot, we have the interface wired up to the computer via serial port, it seems that when we press the program button the LED turns orange like the directions says its suppose to, but when we go to download the program the LED resets and then it starts blinking again and on the screen it says that the download could not make a connection with the interface, so, does anyone have any suggestions?
Unread 20-09-2005, 11:08
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Trouble with Programming the EDU Bot
I had the same problem.
What worked for me was to hold down the program button, click download, and then release the button.
Hope this helps you out.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 20-09-2005, 11:22
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I actually just suggested that in the other current programming thread
Unread 21-09-2005, 10:58
FRC #1611
Yes we have these ways i think our serial cable is bad or the port is messed up, we dont know we just have to think of something
Unread 21-09-2005, 11:14
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I've seen bad serial cables exhibit this exact problem. Try swapping it with another cable, preferably one that is known to be good. The other thing to check is the port configuration. Make certain the baud rate, number of bits, stop bit and parity are set correctly. This is usually done through the OS on the laptop.
Unread 21-09-2005, 11:19
FRC #1611
Were not using a laptop, does that make a difference in anything? Or can you use a desktop as well?
Unread 21-09-2005, 14:22
Back after 4 years off
FRC #5279
It should actually work better with a desk top they tend to be far less tempermental at least when you are dealing with ports.
Other things to check...
Cable, take any that you have and try it
download newest ifi loader
Unread 22-09-2005, 18:46
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Just for clarification, they are no longer called EDU Robots, they are now Robovation robots.
Unread 23-09-2005, 22:05
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Let people call them what they will. If that's what it was called when it came out, that's what it is.
Unread 23-09-2005, 22:37
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Have you tried it with AC power connected vs with battery? We had some issues programming several vex controllers with some WPI owned laptops, where it wouldn't work if there wasn't ac power connected (wouldn't work on battery). Took us a while to figure it out.
Unread 03-10-2005, 10:55
FRC #1611
How did you have the AC hooked up to the EDU Bot, it seems if you were to put more then 7.2 volts it would damage the interface. The only place on the interface to hook up any source of power would be the battery.
Unread 03-10-2005, 11:30
FRC #5279
I think he means AC power to the laptop, to the best of my knowledge you can't (easily) run the edu rc on ac power, check my post in the other thread (the one by muy deficil)and see if it helps.
Unread 11-10-2005, 10:12
muy dificil muy dificil is offline
FRC #1611
muy dificil is an unknown quantity at this point
Alright this is totaldomination under my friends account, i think i may have found the problem wut version of the compiler do u need to run the programming succesfully?
Unread 11-10-2005, 10:15
FRC #1611
We used 1.0.7 for the ifi loader and 6.3 with the compiler.
Unread 11-10-2005, 10:58
Those should work fine with the EDU.
The 6.3 is the version of MPLAB not the compiler. To see what version of the C compiler you're using, look under c:/mcc18/README.C18 and the version will be at the top.
What version of the EDU code did you start with?
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
sphere bot Veselin Kolev Technical Discussion 36 03-03-2005 00:03
Book on C programming - suggestions? wun Programming 18 14-01-2005 00:12
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
