Go to Post It is a good idea to try to stand in another person's shoes and treat them as your equal. It's called respect. - Jaine Perotti [more]
Unread 21-09-2005, 14:47
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Using Spikes to emulate Victors
Originally Posted by Greg Needel
look for speed controllers that utilize a pwm signal and you will be guaranteed it will work. pwm is a standard in the RC industry.
You will also want to look at the voltage range it will operate at. Most R/C speed controllers are designed for 7.2 to 9.6 VDC, but some will work at a higher voltage. Also, make certain that the max continuous and peek current ratings are compatible with what the motor you will be driving and what it is capable of drawing.
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Calibrating Victors SpaceOsc Control System 27 19-11-2004 07:59
extra victors and spikes allowed? gail OCCRA 12 13-11-2002 14:17
What subtitutes controllers, radios, Victors and Spikes? Digo Technical Discussion 6 15-05-2002 16:04
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
