Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 18-09-2005, 20:01
iheartpi iheartpi is offline
OCCRA team 17 (formerly 23)
AKA: Alicia
FRC #1481 (AWESOME-O)
iheartpi is on a distinguished road
Send a message via AIM to iheartpi
[OCCRA]: Programming
I knew at the programming and controls workshop there was talk of posting the modifications to the default code from the advanced workshop here. Just curious if someone is still planning on doing that.
Unread 19-09-2005, 11:03
troy_573 troy_573 is offline
Team 573 (No Place Like Home)
AKA: Troy
FRC #0573 (The Mech Warriors)
troy_573 is an unknown quantity at this point
Send a message via AIM to troy_573
Re: [OCCRA]: Programming
Yup, i have already modified are code to use potentiometers, i just need a robot to test and debug the code with
Unread 19-09-2005, 19:41
AKA: Alicia
Hmmm I was under the impression that both the presentations made at the workshops and the code would be posted in th white papers. Please correct me if I am wrong. I'm sure that people just haven't had time to post yet. I guess I'm just way to excited about our robot, but then again who wouldn't be, we are rolling.
Unread 19-09-2005, 22:39
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Reminder: Programming is NOT required and the OCCRA inspectors or support staff will not assist a team in de-bugging their program at an event. You are on your own if you mess with the code.
Also, teams are not required to share their code modifications. I would caution a team in using anothers code without fully understanding what the results will be and how the code affects the robot performance.
To all rookie teams: Programming will not give a team a significant advantage in the OCCRA competition. You will be just as competitive with the stock code as all teams are required to use 4 joysticks - un modified, and may not add switches, buttons or creations to the stock specifications given for the operators station.
Mike Martus
Unread 21-09-2005, 14:52
CBaoth CBaoth is offline
OMG HAX 4 L1FE NOT JUST CHANUKAH!
None #1489 (Fighting Tuna)
Team Role: Student
CBaoth will become famous soon enough
Send a message via AIM to CBaoth
i disagree, changing minor things like the speed of motors and switching what bottons go to what can make a huge diffrence
Unread 21-09-2005, 18:02
occra 23.
AKA: ryo
None #1481
speeds of motor? as in trying to match the right and left motors so itll go straight? well we have been having the driver(me) compensate for that mostly. any tips on how to do that simply?
Unread 21-09-2005, 20:30
Team Role: Student
uhh not really i mean like even when geared agaist speed and it still goes too fast for drivers then we reduce sensativity...
Unread 21-09-2005, 21:23
You can switch the buttons without programming.
Mike Martus
Unread 21-09-2005, 23:50
occra 23.
AKA: ryo
None #1481
geared against speed. like geared low? (high ratios)?
i am assuming you just switch around the pwms?
Unread 22-09-2005, 19:50
IFI has a map of the PWM outputs and the joysticks. Yes, switch the PWM, use the chart. If you search Chief Delphi you will find it.
Mike Martus
Unread 22-09-2005, 21:37
occra 23.
AKA: ryo
None #1481
or trial and error. unless you use like 10 spikes. (which im not even sure is legal or not) it takes like 5 min at the most. not hard. and if you wanna change which button on the joystick, like thumb or finger, switch the m+ and m- wires around on the spike . same with victors.
Unread 28-09-2005, 18:32
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
I have posted the Code demostrated at the Programming seminar to the White Papers - Programming section of this site. If you have specific quesitons, contact me at jez@dcx.com
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 06-10-2005, 18:34
Team Role: Student
clearly youve never met the kids who do wiring for Roeper... it takes them an hour or two to decided who should do it...
Unread 19-10-2005, 20:11
oaktown1188's Avatar
oaktown1188 oaktown1188 is offline
AKA: Melissa
FRC #1188 (Oaktown Crewz)
oaktown1188 has a spectacular aura aboutoaktown1188 has a spectacular aura about
Send a message via AIM to oaktown1188
We are having a problem with our robot, and we believe it may be in our controls. As we are driving the robot locks up, and doesnt move as if it were not recieving a signal. The two pmw and relay lights are constantly flashing red and we are not sure of the cause of this or if it is related to the sudden stopping of our robot. We had two (old) fuses blow and we replaced them so that could be a source of a problem but it doesnt seem as though that is it, none of them has blown since, or got hot. We have also looked for problems in the OI, the wiering, controls etc. Anyone with a tip would be greatly appreciated. Thank you!
Oaktown Crewz #1188
Ashley S.
Unread 19-10-2005, 20:19
AKA: Troy
i reallt cant tell you much without seing your robot but, if you are using the 2005 first default code and have not removed the "CMU code" all the red PWM cables will flash other than that check to make sure your radio's are connected properly .....ooohhhhh last year at the occra championships our robot became jurky and we checked everything we could think of and after the compition i went into the electronics box and our main ground wire had came undone ... hope i can help
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
