Go to Post FIRST is supposed to be a learning experience. Learn first, win awards later. - evulish [more]
View Poll Results: What is your favorite material for making a robot frame?
metal (if you like a specific type list it) 44 89.80%
wood 0 0%
plastics (all types) 2 4.08%
carbon fiber composite 3 6.12%
other (please list) 0 0%
Voters: 49. You may not vote on this poll
Unread 21-09-2005, 19:38
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Construction materials
I'm curious about what everyone thinks is a good material for frame construction. If you have a specific please feel free to mention it. I'm more curios about the strength than cost.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 21-09-2005, 19:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Construction materials
Aluminum (Or if you're RAGE/571, wood )
Don't use steel. Ever. We did in 2002, for some insane reason thinking we would need the extra strength with all the robot on robot contact. Well, a frame made of 1 1/4" steel angle 0.125" thick ended up taking almost half of our allotted weight--with nothing on it.
Needless to say, aluminum would have worked just fine, and we would have had the weight for a lot of components that got scrapped because the thing was so darn heavy.
P.S. Perhaps you want to make this a poll.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-09-2005, 19:53
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Just like the commerical said: plastics make it possible. If it were cheap enough, I would make everything out of plastic.
BTW, what possible reason would they have to make those plastic propoganda commericals. Are there really enough people that feel strongly enough against plastic that they have to launch a propoganda campaign?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 21-09-2005, 19:57
Billfred's Avatar
Billfred Billfred is online now
Aluminum's done the job for 1293 on both robots.
Although that lexan splash guard we put on underneath the bubble maker (to keep the Victors and RC below nice and dry) does look pretty nice...
(By the way, this is why you shouldn't throw out all of those scrapped ideas immediately--that same piece of lexan was going to be a mounting board for electronics, until we changed the design on the arm. And an earlier version of our winch side plate became our extended battery holder.)
Unread 21-09-2005, 20:11
Personally we didn't like our aluminum because it bent. It wasn't even at the joints it was the beam itself!
Unread 21-09-2005, 20:12
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Team 836 likes to use a combination of aluminum plate, angle and square tubing, plus 80/20. Very sturdy, easy to work with and tons of ways to use them. and for everything else lexan.
Unread 21-09-2005, 20:34
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Its not the type of material you use, but how you use it... remeber those bridges you build out of 1/8x1/8 balsa wood and elmers glue that would weigh 50 grams and hold 50lbs?
Unread 21-09-2005, 20:35
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
If you want favorite material to work with as far as budget goes aluminum by far but if money was no object i would be using a titanium or carbon fibre. both of which have their disadvantages (titanium-dulls drill bits and other cutting tools fast)(carbon fibre-expensive and must be custom made for the most part)
So aluminum is easy to work with light and fairly strong.
MechWarriors 573
Unread 21-09-2005, 20:50
Cory's Avatar
AKA: Cory McBride
What type of aluminum were you using, specifically, and what was it used for?
2001-2004: Team 100
Unread 21-09-2005, 20:59
Yeah but a 1/8x1/8 titanium is going to work much better then balsa. However i agree engineering has a HUGE aspect on your strength. Also making frames out of carbon fiber is not as expensive as it seems.... But yes you do have to form it yourself (its not as hard as it seems). I probably should have included fiberglass too but i don't think anyone here used it.
Unread 21-09-2005, 21:19
Andrew Blair's Avatar
FRC #0306 (CRT)
Titanium is not all it's cracked up to be, at least from a FIRST aspect. Its extremely strong, but so is steel. Titanium is is like 30% as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about!
Check this PDF out: http://www.engr.ku.edu/~rhale/ae510/titanium.pdf
-Sir Francis Bacon
-Albert Einstein
Unread 21-09-2005, 21:23
Originally Posted by Andrew Blair
Titanium is not all it's cracked up to be, at least from a FIRST aspect. Its extremely strong, but so is steel. Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about!
However it does make painting your robot easy! You can anodize aluminum with a 6 volt battery and soda. Who wants to paint the Guggenheim red? Anyone? Wouldn't that be amazing! robots doing drive bys on other robots... except for the whole safety thing.... I'm just trying to picture a gangster robot.
Unread 21-09-2005, 21:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Aluminum box tubing (square and recangular) has been the material of choice for 696 since 2004. Previously we had used Bosch 30x30 extrusion but then we realized that it was too heavy especially with all the corner brackets and fasteners.
I'd say if your base frame is more than 15lbs and it's not a crab drive, you need to rethink it.
mechanicalbrain, what exactly did you have bend and what were the circumstances under which it bent? Any pictures?
Unread 21-09-2005, 23:05
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Please someone correct me if I'm wrong but I think you are not allowed to use exotic metals in FIRST which would include Titanium.
Also my team has used 8020 and .125 aluminum, but next year we are thinking box aluminum or 90 degree corners depending on the game.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 21-09-2005, 23:11
Cory's Avatar
AKA: Cory McBride
Dave
They changed the rules.
You can use titanium, but you have to account for the price of it in your BOM.
$3500 isn't going to go a long ways towards building a robot, and buying Ti.
2001-2004: Team 100
2005 Championship Conference materials available! dez250 General Forum 1 09-05-2005 11:29
Promotional Materials Amanda Morrison General Forum 9 02-04-2005 14:02
Materials Jeff K. General Forum 11 22-01-2005 02:24
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
