Go to Post I'd like to think FIRST hasn't completely transformed into a money hungry self serving corporation. I'd like to think they actually still think they care about us. - Koko Ed [more]
Unread 22-09-2005, 08:41
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: Array problems( i think....)
i know this isn't the problem you're currently working on, but it will be soon.
in your replay code at the end of the while loop i will be 90. the if statement that follows will fail because i will not be greater than 90, so your pwm will stay at the last recorded value and you bot will keep running. very bad.
there is no need for a conditional at all, since when the loop stops you want the robot to stop.
Array Problems: Possible<stdio.h> Alex Wijtowych Programming 7 26-01-2005 04:39
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
