Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
View Poll Results: What is your favorite material for making a robot frame?
metal (if you like a specific type list it) 44 89.80%
wood 0 0%
plastics (all types) 2 4.08%
carbon fiber composite 3 6.12%
other (please list) 0 0%
Voters: 49. You may not vote on this poll
  #31   Spotlight this post!
Unread 22-09-2005, 14:06
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Construction materials
I think my personal favorite is a carbon/Kevlar composite plain weave with a heavy duty epoxy. Yes you do have to form it yourself but its actually pretty easy and not horribly expensive. The shaping is actually good because you can customize the shape of the frame without having to lose strength. Also It has a good strength to weight ratio (the exact ratio escapes me).
Also one critical thing Ive failed to see mentioned are the types of strength materials have . A materials type of strength defines its function. The Kevlar gives a great tensile strength and torsional strength. Yet the carbon gives the weave good transverse strength and amazing impact resistance. However I recommend practicing the process and familiarizing yourself with the materials. If you don't form it evenly or use the right types of epoxy and weave you will create weak points.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
  #32   Spotlight this post!
Unread 22-09-2005, 16:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
696 has used welded 6063 1/8" wall aluminum box tubing frames for the past two years. 6061 was not available. Anyway, we have had virtually no problems with the 6063 and have only cracked (very minorly, no repair needed) a weld once ever. The 6063 polishes very nicely too. As with any welding, be prepared for warpage and have a plan to correct it (or prevent it)
  #33   Spotlight this post!
Unread 22-09-2005, 16:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I wouldn't use carbon fibre as the sole material in a frame.
There was a thread about using it in different robot applications, about a year ago. I noted then that if you scratch something made of carbon, even cosmetically, you can cause it to catastrophically fail, with no warning like with metals that will bend.
Seeing as a frame is probably going to get the hell scratched out of it, that doesn't sound too appealing to me.
It's not an easy material to work with either. It can be very hazardous to your health if you don't have a good understanding of what you're doing and take safety precautions.
2001-2004: Team 100
2006-Present: Team 254
  #34   Spotlight this post!
Unread 22-09-2005, 16:17
Ive worked with carbon fiber on a multitude of modeling projects and Ive never had the problem you've described. Actually if you use the correct epoxy it will be hard enough to scratch it. Actually the structural characteristics of carbon fiber are completely altered by the weave, material, and epoxy. As to being hazardous. Epoxy is essentially a glue. Use a respirator and work in a ventilated area and you'll be fine. It really isn't dangerous as long as your not directly breathing in fumes (I think thats the case with almost all chemicals). Oh and make sure to use gloves and long sleeve shirts.
  #35   Spotlight this post!
Unread 22-09-2005, 20:08
Andrew Blair's Avatar
FRC #0306 (CRT)
Yes, Ti is about the perfect medium between aluminum and steel, but as for frame building, not so much. The more I think about it, it would be useful for small parts though.
-Sir Francis Bacon
-Albert Einstein
  #36   Spotlight this post!
Unread 22-09-2005, 20:37
Cory's Avatar
AKA: Cory McBride
http://en.wikipedia.org/wiki/Scandium
2001-2004: Team 100
  #37   Spotlight this post!
Unread 22-09-2005, 21:01
I know they use that in bicycles but i don't know anywhere where you can buy it. I tried to google it but nothing promising showed up. Any good links?
  #38   Spotlight this post!
Unread 22-09-2005, 21:11
Cory's Avatar
AKA: Cory McBride
It's way too cost prohibitive for FIRST use. I don't know where you can buy it in it's raw form.
it's original use was on USSR ICBM's on submarines under the polar ice caps. The missiles would have their fins ripped off, so they started making them out of an alloy of scandium and aluminum, giving them the strength to punch through the ice.
2001-2004: Team 100
  #39   Spotlight this post!
Unread 22-09-2005, 22:14
FRC #0306 (CRT)
"Scandium metal powder is combustible and presents a fire hazard."-wikipedia
haha, great, electrical fires and chemical fires!
-Sir Francis Bacon
-Albert Einstein
  #40   Spotlight this post!
Unread 22-09-2005, 22:16
Cory's Avatar
AKA: Cory McBride
That's why you wouldn't use it in it's powder form
It's no different than magnesium--it's highly flammable when in strips/powder, but it's used for various other things in a more solid state.
2001-2004: Team 100
  #41   Spotlight this post!
Unread 22-09-2005, 22:25
http://en.wikipedia.org/wiki/Magnesium cool stuff really. What would FIRST say if we told them our robot was made of magnesium (I know, I know, Its near impossible to burn the bulk stuff) Much lighter than aluminum.
  #42   Spotlight this post!
Unread 26-09-2005, 00:13
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
whilst looking for an aero seat tube for the composite TT bike i'm (hopefully) going to build, i noticed that easton sells scandium alloy tubes used in high-end mountain and road bikes.the selection is very limited, but if you absolutely have to scratch that scandium itch, here's a trustworthy* place. they also manufacture components made from carbon nano-tubes, but i don't see any tubing made of CNTs...yet.
*i assume since a large number of distributors and manufacturers trust them, we can too.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
  #43   Spotlight this post!
Unread 26-09-2005, 00:17
Cory's Avatar
AKA: Cory McBride
I don't think Easton sells these directly to the consumer. As far as I know, they sell them only to the manufacturer of the bikes (of which, only one or two companies use it).
Easton is most certainly a trustworthy company as far as quality of product goes. I don't know much about their baseball bats/hockey sticks, but their bicycling products routinely exceed their strength parameters by 3-4x.
2001-2004: Team 100
  #44   Spotlight this post!
Unread 26-09-2005, 01:44
RogerR's Avatar
AKA: Roger Riquelme
I don't think Easton sells these directly to the consumer. As far as I know, they sell them only to the manufacturer of the bikes (of which, only one or two companies use it)...
i assume that you'd be able to get materials and components from one of their international distributors. in the US, it appears to be a company called Veltec Sports Inc. I plan to contact them in the future to see about buying some materials, and if it's still relevant, i'll post what kinda response i get.
  #45   Spotlight this post!
Unread 26-09-2005, 01:55
Cory's Avatar
AKA: Cory McBride
When they say "distributor", I think they're referring to finished parts, not semi-raw materials.
At any rate, bicycle tubing is probably fairly hard to work with. I know Scandium isn't easy at all to weld. It's also extremely cost prohibitive. A plain bicycle frame made of the stuff is around $2000+. After all is said and done, for FIRST exotic metals probably wouldn't offer much of a tangible advantage over plain aluminum when used properly.
2001-2004: Team 100
2005 Championship Conference materials available! dez250 General Forum 1 09-05-2005 11:29
Promotional Materials Amanda Morrison General Forum 9 02-04-2005 14:02
Materials Jeff K. General Forum 11 22-01-2005 02:24
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
