Go to Post thats like having 24 young men going wild for 2 minutes - thats how much power is available during a match. - KenWittlief [more]
Unread 16-08-2005, 02:26
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: pic: Team Fusion's T-Shirt Shooting Robot
I suppose this would definatly be an attention getter and spread the team a little. Jow did you go about getting permission to do it? or did no one really care? Just curious.
_Mike
Unread 16-08-2005, 11:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Originally Posted by mechanicalbrain
I'm not sure you would want a revolving reloader. You would need a way to maintain pressure.
Discovery Channel fans may remember the Monster Garage epidose when they made the Delivery Truck. A small air cannon was mounted on the top of the truck and had four rotating barrels. When rotated, the barrels would slide forward; when they were lined up with air valve, they slid backwards a bit onto it making the seal. I can't find any real good pictures online of it, but here is one that at least shows it:
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-08-2005, 11:41
bhweezer's Avatar
bhweezer bhweezer is offline
Brandon Higgs
FRC #0364 (Team Fusion)
bhweezer is a jewel in the roughbhweezer is a jewel in the roughbhweezer is a jewel in the rough
Send a message via AIM to bhweezer
Originally Posted by sanddrag
Also, do you have a video of this thing in action? I find it hard to believe that a shirt can go that far on that little pressure (but then again I have never built one). Maybe it is just a massive volume of air and a fast valve that does the trick?
_Mike
I will make sure we get some pictures and video after the first football game, but that will not be until the 26th.
All we really did was demonstrate it for our principal a couple of times and then no one had a problem with it.
Team Fusion (364)
Synergy in Motion
Unread 16-08-2005, 11:48
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Did you use the stock KOP air compressor? If not what did you use?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 16-08-2005, 12:17
bhweezer's Avatar
Brandon Higgs
Everything on the robot was from our 2004 competition bot. We used the KOP compressor and left all of the pneumatic parts on the robot. The only significant change we made was we let the electrical team rewire the robot before last years build season.
The only down side to using the KOP compressor is that it takes a couple of minutes to build the pressure up. If we take our time reloading shirts then it isn't a problem.
Team Fusion (364)
Synergy in Motion
Unread 16-08-2005, 16:21
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
The problem with that idea is you need a way to separate the shirts. Maybe give the shirts a casing like wrap them in saran.
The problem with Saran wrap is that it is made to cling, so it might cling to the PVC. Not that it always clings when and where I WANT it to!
Now I'm trying to picture what would happen to a T-shirt shooter with the T-shirts wrapped in cling wrap, especially if they did stick inside.
Karen Husmann
Ex Robo-widow
Unread 16-08-2005, 16:29
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Well obviously not saran itself (although actually i would work since i believe it sticks though static which means it wouldn't really stick under pressure) but a thin plastic wrap will make the shots much better.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 16-08-2005, 17:11
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
jdhawg will become famous soon enough
We did try using Soft Drink bottles cut in half and the t-shirts rolled up and stuffed inside. They fit perfectly, but tended to flip over and go 'heavy end first' into the crowd. Now we put two or three rubber bands around the shirt and let 'em fly!
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
Unread 28-08-2005, 17:18
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Originally Posted by NoodleKnight
What are you using as the valve? SCH40 PVC is good up to it's pressure rating, which should be printed on the tubes, and I think it's far past 250 psi. The PVC joints are always built stronger than the pvc piping, so as long as you cured/glued the joints correctly, all will be fine.
I always like to put my psi limit depending on the valve, I usually use a normal sprinkler valve, which is good to 120 psi; so I set mine to 100-110 psi and it can shoot stuff far enough for my purposes. If you're using a ball valve, you could go higher, but at that point I'd be scared, lol. I suppose you could make some type of scatter shield for it.
If you're having problems shooting the t-shirt high up into the stands, try cramming the shirt down the barrel, hard. You don't want any air bleeding past the t-shirt.
I was looking at sprinkler valves and the ones I saw were 24 V AC. How did you power yours?
Allan
Unread 28-08-2005, 18:57
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Allan
This project so inspired me, I had to have one. So, I built it. Now it is on our bot from 2005. We demo'd it at Freshman orientation night, talk about a hit!!!
We used a non-flow regulated in-line 1" valve from Rain Bird. I had the same question about the 24vac coil and 12vdc supplying it. All I have to say is, it works great. We are using a spike to trigger it.
Unread 28-08-2005, 21:50
bhweezer's Avatar
Brandon Higgs
We have videos of our cannon at a football game and a pep rally. I am going to post them after we get through with this hurricane.
Team Fusion (364)
Synergy in Motion
Unread 28-08-2005, 22:14
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Does anyone have plans for this sort of thing? How do you release that pressure?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 05-09-2005, 12:55
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Wow, we should make one of those for the football games... it could replace our QB
JT
229
Unread 25-09-2005, 14:09
Andrew Blair's Avatar
FRC #0306 (CRT)
Where did you guys buy your pvc tank?
-Sir Francis Bacon
-Albert Einstein
Unread 25-09-2005, 14:54
Uh I don't think you buy PVC tanks you can make them quite easily though. Where are the videos!!! Ive been waiting!
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
