Re: Rigging a PC power supply
Another option is to use an old AT power supply - I have a couple from old PC's that have since been recycled. They require no minimum current and no pin-shorting to work. I used to use one as a basic bench supply before I got a real one.
Another thing to keep in mind when you eventually get tired of that big honking connector with just 2 shorted wires is that if you cut it off and just connect the green wire to a black one (perhaps even inside the power supply housing to keep it clean), often the supplies won't work. I found out the hard way that on some supplies you have to see which wires are joined at the connector and reconnect those wires as well.
For a PowerUp! 6100D model (cheap with loads of current capability), there are 2 orange wires and 2 black wires joined at the connector -- the power supply just will not work with out both those pairs wires joined (in addition to the grounding the green wire trick). Good luck. Joe J. |
Funny but i always said tubaware. Yeah if you don't have a project case or can't find one big enough use this stuff. Its amazing!
| Additional basic stamp servo power supply | John Gutmann | Electrical | 11 | 21-09-2005 21:45 |
| need Computer power supply trick | Tytus Gerrish | Electrical | 7 | 20-01-2005 11:25 |
| 12V Power Supply Feeds My Robot | MikeDubreuil | Electrical | 17 | 31-03-2004 12:06 |
| operator interface power supply | hi_im_sean | General Forum | 1 | 05-02-2003 14:50 |
| power supply of control system | archiver | 2000 | 5 | 24-06-2002 00:14 |
