Go to Post Figuring out how to do something is half of the fun. - Mike [more]
Unread 26-09-2005, 15:56
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
Re: Rigging a PC power supply
Originally Posted by BrianBSL
Another option is to use an old AT power supply - I have a couple from old PC's that have since been recycled. They require no minimum current and no pin-shorting to work. I used to use one as a basic bench supply before I got a real one.
I'd be careful with an old AT supply, power supplies have gotten much better, many of those old supplies wouldn't regulate unless they were loaded, which would let the magic smoke out of anything you are working on.
Unread 26-09-2005, 17:37
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Another thing to keep in mind when you eventually get tired of that big honking connector with just 2 shorted wires is that if you cut it off and just connect the green wire to a black one (perhaps even inside the power supply housing to keep it clean), often the supplies won't work. I found out the hard way that on some supplies you have to see which wires are joined at the connector and reconnect those wires as well.
For a PowerUp! 6100D model (cheap with loads of current capability), there are 2 orange wires and 2 black wires joined at the connector -- the power supply just will not work with out both those pairs wires joined (in addition to the grounding the green wire trick).
Good luck.
Joe J.
Team #88, TJ2
Unread 26-09-2005, 19:01
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Heh Ive let that magic smoke out of so many electronics that my mentor calls me smoky (I'm not joking he really does). Well it works fine. I'm going to house it in a tubaware and put in switches so i can turn off wires and not half to worry about contact. Thanks all this is perfect for a quick power source.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 27-09-2005, 10:54
Originally Posted by mechanicalbrain
...I'm going to house it in a tubaware...
In a what?
Unread 27-09-2005, 11:06
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
In a what?
I think he means Tupaware, like that plastic stuff that moms with nothing to do sell in parties. It's good stuff. The Tupaware, I mean.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 27-09-2005, 11:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I think he means Tupperware, the plastic containers with snap/press on air tight lids for storing food.
Unread 27-09-2005, 12:23
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
That's what I ment. I can't spell. Sorry. I think that's what "tubaware" is.
// random()
Unread 27-09-2005, 15:23
Funny but i always said tubaware. Yeah if you don't have a project case or can't find one big enough use this stuff. Its amazing!
Additional basic stamp servo power supply John Gutmann Electrical 11 21-09-2005 21:45
need Computer power supply trick Tytus Gerrish Electrical 7 20-01-2005 11:25
12V Power Supply Feeds My Robot MikeDubreuil Electrical 17 31-03-2004 12:06
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
power supply of control system archiver 2000 5 24-06-2002 00:14
