Go to Post At the end of the day the game is what brought us to the location, but its the people that got the party started. - IronicDeadBird [more]
Unread 26-09-2005, 17:27
firetrap firetrap is offline
firetrap is an unknown quantity at this point
Programming Vex Starter Kit To Recieve From Serial Port
Dear All
will be really grateful if any one could give me any help concerning the following (as I am not capable of accomplishing such a task without your help) :
I just brought the vex starter kit which contains a microcontroller ( consists of 2 PIC18F8520) and I want to bluetooth enable the kit (control the robot using bluetooth) . so I will connect a bluetooth module to the serial port of the microcontroller and ill connect a bluetooth dongle to my pc & I brought also the vex programming module .
The Main Problem :
the microcontroller must be re-programmed (edit the default code) to receive from the serial port instead of receiving from the rx port and I think this program is related to the terminal emulation software or any other application that ill use to control the robot .
so if you could please help me in editing the default code of the vex starter kit
http://www.vexlabs.com/docs/VexStartupCode.zip
http://www.vexlabs.com/docs/vex-default-firmware.zip "is a hex file"
your kind technical assistance and advices will be highly appreciated , thank you for your kind concern and attention and please accept my warm regards .
P.S :
I am not a programmer and have no background about this area , so please advice me with any necessary hints about the variables that I must use in the terminal emulation software or any other application and any other notes to be considered or useful to me in this concern , so I can advise any one of my friends who is experienced in programming , so he can do it (an application to control the robot) correctly .
VEX Programming Kit Available On-Line Ken Delaney 357 FIRST Tech Challenge 6 02-10-2005 11:25
Vex programming kit finally available?? rswsmay General Forum 20 27-09-2005 22:08
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
